So In my video directory I right clicked on a video, selected copy, then pasted that copy into a blank space creating a duplicate. After that I noticed that both files are exactly 99.2 MB in size but the original video was only about 35 MB!!
Why did this happen and how can i restore the file to it's original size!!??
Closed Thread
Results 1 to 17 of 17
Maybe it's an Apple computer? Both Noahtuck and hech54 are correct. Something went terribly wrong when you copied that file. You don't just copy and paste into a "blank space" (whatever that means). You copy and paste into another folder if on a Windows PC if you want to retain the same file name.
I see the same thing from time to time. Windows Explorer sometimes fails to update the directory listing at the end of a process that involves writing to a file, so the file appears smaller than it really is. Refreshing the window normally corrects the listing. It seems to be a fairly common Windows 7 glitch.
MaddogX, as a newcomer, you probably haven't been on the forums long enough to note hech54's recurrent tendency to be harsh rather than helpful, although he sometimes chooses to be very helpful. Stick around and you will see it time and again. Hard to fathom the "why" of this behavior, other than maybe an occasional streak of misanthropy, a little "Dr. Jeckyl & Mr. Hyde."
Just ignore him as "Hyde" and take note of the occasionally helpful "Jeckyl."
Sorry guys, false alarm.
I had just changed the bit rate of that file in vlc and my directory did not update the changes to the file until I made a copy of it. I had to download an original copy and change the bit rate again to figure it out. I just wasn't expecting the MB to jump so high with such a minor change!
Thanks anyway for the help.
You just validated what hech54 said, although I think what we have here is a case of a user, you, not telling us exactly what they were doing and expecting us to figure it out by reading your mind. How exactly were we supposed to know that you used VLC for this purpose when your original post said that you simply did a copy and paste?
[QUOTE=jman98;2112758] The conversion process had been done for over an hour at least. Thus, I didn't think it was relevant seeing as how I do this all of the time with virtually no changes made to the file size. The 35 MB size I alluded to was there long after the conversion process was over. In fact, I forgot it was a new file. What hech54 said was that I didn't just witness what I described and technically I did but obviously it was a glitch and not my imagination. I think you will find a large portion of failures to diagnose a problem in this section result form not taking a particular factor into account. Actually, most if not all diagnostic failures result from this and I don't see anybody else being bashed for it.
No, technically you didn't, since there wasn't any copy and paste involved but a full reencode. And then you called him out on it:
And he was 100% right and you're still trying to justify yourself? Give up already and apologize to him.
Need help cutting out video segments and making one video with them
By darkcyber in forum DVD RippingReplies: 2Last Post: 23rd May 2011, 17:26 -
Youtube increases time limit to 15 minutes.
By aedipuss in forum Latest Video NewsReplies: 30Last Post: 31st Jul 2010, 17:46 -
Making a copy with DVD santa
By 1234567 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jul 2008, 02:19 -
making a video CD
By d_razaq in forum Newbie / General discussionsReplies: 8Last Post: 21st Sep 2007, 22:41 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 07:20
