hey
i got a blu ray player phillips BPD2700/12. Now i got 2 problems:
1) i can't play all movies ( videoformat not cappable)
2) some movies play but with no audio ( audioformat not cappable)
i play my movies from a extern hard disk (USB)
can someone help??
thx
PS: my english isn't that good, srry for wrong spelling
Results 1 to 9 of 9
Movies??? Please provide more information. Avi, mkv, etc.
But if yo want to play everything get a htpc or wdtv live or similar. -
Your English is fine. I've seen worse from native speakers here, sadly.
What is you native language? We've got some people here who speak various languages so you might be able to get help in your native language if you tell us what that is.
As Baldrick says, we need more information. Probably you are not playing BluRay movies and that's why you are having problems. Install the program MediaInfo and post the information here that it gives you when you open a movie in it that you have trouble playing. -
I downloaded that new pirates movie , it's a AVI and he doesn't play. but the funny thing is got other movies also in AVI and those movies he play.
I also got a movie in MP4 and that movie he play but the audio not ( audio not cappable for play or something).
PS: i'm from belguim, native language is dutch.Last edited by lema1610; 9th Oct 2011 at 06:55.
this is one of the movies i can't play. it's in dutch, i hope you'll understand.
Volledige naam :E:\thuis\film's\Arena (2011)\The Arena (2011).avi
Formaat :AVI
Formaat/Info :Audio Video Interleave
Bestandsgrootte :1,37 GiB
Duur :1h 34mn
Totale bitrate :2 073 Kbps
Gebruikt programma :VirtualDubMod 1.5.10.2 (build 2540/release)
Gebruikte encoderbibliotheek :VirtualDubMod build 2540/release
Video
Formaat :MPEG-4 Visual
Formaatprofiel :Advanced Simple@L5
Formaatinstellingen, BVOP :3
Formaatinstellingen, Qpel :Ja (yes)
Formaatinstellingen, GMC :3 warppoints
Formaatinstellingen, Matrix :Default (MPEG)
Codec-ID :XVID
Codec-ID/Hint :XviD
Duur :1h 34mn
Bitrate :1 680 Kbps
Breedte :720 pixels
Hoogte :304 pixels
Beeldverhouding :2,35:1
Framerate :23,976 fps
ColorSpace :YUV
ChromaSubsampling :4:2:0
BitDepth/String :8 bits
Scansoort :Progressief
Bits/(Pixel*Frame) :0.320
Stroomgrootte :1,11 GiB (81%)
Gebruikte encoderbibliotheek :XviD 1.2.0.dev47 (UTC 2006-11-01)
Audio
Formaat :AC-3
Formaat/Info :Audio Coding 3
Format_Settings_ModeExtension :CM (complete main)
Codec-ID :2000
Duur :1h 34mn
Bitrate-modus :Constant
Bitrate :384 Kbps
Kanaal(en) :6 kanalen
Kanaalposities :Front: L C R, Side: L R, LFE
Samplerate :48,0 KHz
BitDepth/String :16 bits
Stroomgrootte :259 MiB (19%)
Uitlijning :Gesplitst over interleaves
Interleave, duur :42 ms (1,00 videoframes)
Interleave, preloadduur :500 msLast edited by lema1610; 9th Oct 2011 at 12:15.
It's OK that it's in Dutch. I understand why this file won't play.
1) QPel is a problem for some players. Your file has it. This was more of a problem in the past than with modern players like yours. However...
2) You have GMC with 3 warp points. This will NEVER play. No DVD or BluRay player is known to support more than 1 warp point with GMC.
To get this file to play on your BD player you will have to re-encode it. I suggest removing both QPel and GMC. Others may be able to suggest a user friendly program you can use for that as I use something fairly advanced for encoding AVI files and I don't think you would want to use it. -
Easiest is to reconvert with avi recomp.
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 03:35 -
Copyed Blu ray won't play in blu ray player
By gweedow in forum Video ConversionReplies: 6Last Post: 13th Jan 2011, 14:58 -
Blu Ray Player won't play some DVD backups
By Turpulus in forum Authoring (Blu-ray)Replies: 3Last Post: 14th Apr 2009, 02:00 -
How do you play Blu-Ray movies at 60 frames per second?
By Obamargarine in forum Software PlayingReplies: 2Last Post: 26th Feb 2009, 22:19
