Results 1 to 9 of 9
  1. Hey there people, so here is my problem.
    I have 2 videos both .mkv h264 :
    - The first one it is just a 10 secs credit video that I made with after effects
    - The second one it is the main video
    The first one has to play before the main video, and the main video has a softsub file.
    How can I merge both videos using megui and save that new file as .mkv h264 ?
    Sorry if someone already ask that, i tried to search and didn't find anything.
    Thank you very much in advance.
    mkvmergegui can join.
  3. Originally Posted by Baldrick View Post
    Well, I tried but it didn't work it. The first video, works just fine but when its over the main video didn't show up. It get stuck at the "last image" of the credit video. The sound worked just fine, but I can't see the video or subs.
    Aug 2011
    Australia
    I know this is an old thread but I'm having the same problem
  5. Originally Posted by shagratt71 View Post
    Let's say you have 2 videos [ video01.mp4 and video02.mp4 ], when you're writing your avs script just copy and paste the line for video02. Like this:
    DirectShowSource("E:\path to the file\video01.mp4", fps=23.976, audio=false, convertfps=true).AssumeFPS(24000,1001)
    DirectShowSource("E:\path to the file\video02.mp4", fps=23.976, audio=false, convertfps=true).AssumeFPS(24000,1001)
    I'm using megui to do that since i'm used to it.
  6. I'm a Super Moderator johns0's Avatar
    canada
    To merge the mkv files with mkvmerge you add the first mkv and with the second mkv you choose append,if you get an error then there's something wrong with one of the files or they are not of the same resolution and codecs.
  7. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    That will work but is reencoding both videos.
  8. Originally Posted by AlanHK View Post
    Yes, but I would have to encode both anyway...
  9. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    No, MKVmerge will append files without reencoding.
    See http://www.bunkus.org/videotools/mkvtoolnix/doc/mkvmerge.html
