  1. Hi
    i am trying to get some settings (from ffmpeg how to) and have done the following to no avail.. where am i going wrong? thank you in advance
    Ffmpeg
    -i <input_file>
    -pix_fmt yuv422p
    -vcodec mpeg2video
    -flags +ildct+ilme
    -top 1
    -dc 10
    -flags2 +ivlc+non_linear_q
    -qmin 1
    -lmin 1*QP2LAMBDA
    -vtag xd5c
    -rc_max_vbv_use 1
    -rc_min_vbv_use 1
    -b 50000k
    -minrate 50000k
    -maxrate 50000k
    -bufsize 36408333
    -bf 2
    -aspect 16:9
    -acodec pcm_s16be
    -f mov output.mov
    -newaudio
    Moving you to our video conversion section. ffmpeg is not ffmpegx.
    If you were looking at this page, beware that commandline is broken
    http://www.itbroadcastanddigitalcinema.com/ffmpeg_howto.html
    The newer ffmbc releases have a -target xdcamhd422 preset (since 0.6 beta 2)
    http://code.google.com/p/ffmbc/
    e.g
    ffmbc -i input.ext -target xdcamhd422 output.mxf
  4. Hi
    i am looking at this and i get an error saying unrecognised option 'pix_fmp'
    is there a site that has the codes i can check against to make the xdcam35mbps settings
    thank you
