Hey all, using an iMac with Final Cut Studio 3 on it, and trying to export a project to Quicktime and I keep getting a General Error when doing it. The timeline has an Aspect Radio of HDTV (1080i) (16:9), a pixel aspect ratio of Square, and the compressor is Motion JPEG A. When I try to export it to Quicktime DV Anamorphic NTSC 48 khz I always get a General Error. I tried making up a new timeline, checking my scratch discs have enough space (they do) and even trying other settings, always get the same error. There's no transition or speed up or anything else where is always craps out...any ideas?
T
Results 1 to 9 of 9
Did you pull up your activity monitor to see how much Memory was in use?
Have you gone back through and checked the available scratch disc space?
FCP uses that space to temporarily buffer what it writes, if the scratch disc
is the same that the media files and project are on, it could be the problem.
Also, have you tried selecting the timeline again, and making sure
to render all video? Sometimes a render file becomes corrupt ( bad spot on disc,
general file disc corruption) and sometimes re-rendering will fix everything,
or at least, point to where the problem lies.
Last, have you tried copying everything out, putting it in a new project file, saving that, and trying
the render out, after saving the new project file, and then restarting the iMac?"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Terry, scratch discs are fine, not a problem. I cannot render the video as that causes video jitters when playing back (it was shot on H264 and have found that by exporting it to Quicktime I get around that problem). And yes I copied everything and put it into a new timeline... What can I try next?
Tom -
Hate to write this but do make sure you have the project backed up and then check for bad blocks on the HD.
Tried exporting to both my internal hard drive and an external, same thing happens at the same spot on the project. So I know it's not bad blocks
Maybe the problem is one of the blocks where the source files are located.
Can you export to anything? is every export setting giving you that error, or just that one...
Every export setting is doing it...I had a lot of success last night buy rendering the piece, then exporting...but there were still about 6 pieces still gave me the same problem even after rendering...would not export.
Final Cut Pro Exporting Slows to a near Stop
By JonathanB in forum MacReplies: 2Last Post: 6th Mar 2012, 17:25 -
Help Please! Exporting AVCHD video on Final Cut Express 4 - interlacing
By bs2511feist in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 1st Apr 2011, 02:28 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 13:50 -
Exporting from Final Cut Express to P2 native (MXF?) format?
By Cyrax9 in forum MacReplies: 2Last Post: 1st Jun 2009, 14:55 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
