Hello everybody.
I am the author of Video Thumbnails Maker, listed here at videohelp.com
I want to introduce you another my program - Videonizer.
(wish it will be listed at videohelp.com too)
The official site:
videonizer-soft.com
VIDEONIZER is an Ultimate Video Organizer.
It appears in the form of database manager with handy interface.
Key features of the project:
- supports for both videos and pictures
- it is fast
- password protection to launch the application (option)
- strong database encryption (option)
- built-in categories (Actors, Genres, Sites), Custom tags
- integrated Password manager
- fast login (username : pass) to your site
- handy filtering system
- fast access to videos and pictures from the main window
- ability to choose Video player to play video file
- custom Rating system for both videos and pictures
- Actors, Genres, Sites templates (beans) for quick editing
- fast checksum calculation to prevent files duplication
- neutral application title for 'panic' purposes (option)
- multilanguage interface (English, German, French, Spanish, Italian)
- Tooltips, Hotkeys
Screenshots:
- - - - - The main window - - - - - - - Genres example - - - - - - - - - - Item editor - - - - - - - - - - Password manager - - -
Video tutorials (Youtube, HD, great music):
First Steps
Filtering and Sites
Screenlists and Pictures
Limitations:
http://www.videonizer-soft.com/prices.html
Download links (v1.2.0.4):
Download Page at the Official site
Direct Link (2 MB)
Mirror (2 MB)
Microsoft .NET Framework 4.0+ is required to run the program.
OS: XP/Vista/NT/Win2k/Win7
Results 1 to 13 of 13
Thread: Videonizer
Videonizer has been updated several times since version 1.2.0.4!
Here is the changelist:
v2.1.0.7v2.1.0.6- "Check for updates" feature is added. Press "Check for updates" button to find an update automatically (internet connection is required). If a newer version is found, Videonizer downloads it automatically and makes a suggestion to install
- windows 7 "bad tooltips" bugs are fixed
- tooltip with the current database path is added. Hold the mouse over "DB name" area to popup it
- cursor appearance is changed to "Hand" over active controls everywhere
- few cosmetic changesv2.1.0.5- context menu speed is increased significantly for large/medium databases
- SHIFT + END hotkey is added. Use it to select items from the last selected row to the end of the list
- SHIFT+ HOME hotkey is added. Use it to select items from the first selected row to the first row of the list
- "G" hotkey is added to edit Genres Bean, "SHIFT + G" hotkey is added to apply Genres Bean to selected items
- "A" hotkey is added to edit Actors Bean, "SHIFT + A" hotkey is added to apply Actors Bean to selected items
- "S" hotkey is added to edit Sites Bean, "SHIFT + S" hotkey is added to apply Sites Bean to selected items
- if you can not open a DB for some reason during startup - Videonizer makes a suggestion to create a new DB for you. Thus you will be able to start the program
- fixed a bug when scrollbar becomes black after adding new video files to the list
- default rating apearance is changed to stars
- deutsch translation is completed
- few cosmetic changesCould somebody help to list the program at videohelp.com ?- Videonizer is integrated with Video Thumbnails Maker; "Full Auto" button is added to the item's editor; pressing the button creates a screenlist in background, using current Video Thumbnails Maker settings, and adds the screenlist to the item automatically; works only for activated Video Thumbnails Maker version 3.0.0.6 or higher
- EMPTY / FILLED indicators are added to beans (also works in context menus)
- ASC / DESC indicators are added to sorting buttons
- sorting bugs are fixed
- design improvements -
Videonizer has been updated several times since version 2.1.0.7!
v2.3.0.2v2.3.0.1- non-operable "Open With..." context menu item is fixed
- the dynamic list of video-players to play a video-file from the list is build more accuratev2.1.0.9- new "resolution" column is added to the grid of items; the field is filled automaticaly for every video-item you update or add to the database
- "hall of fame" window is redesigned completely
- a single click on genres, actors, sites, screenlists or photos area in the item's editor window equals to a click on the corresponding "add" button
- restoration of initial directory for dialogs is fixed in the item's editor window
- the size of the main window is increased
- few cosmetic changes, tooltipsv2.1.0.8- strategy to prevent adding duplicate video-files is improved
- several buttons in the main window are rearrangedCould somebody help to list the program at videohelp.com ?- Videonizer is now compatible with UAC (User Account Control under Vista/Win7) -
Videonizer has been updated to version 2.3.0.4!
v2.3.0.4Could somebody help to list the program at videohelp.com ?- the size of all windows is increased
- active window border is highlighted with lavender color; also lavender color is used to highlight buttons and grids
- new "duration" column is added to the grid of items; the field is filled automaticaly for every video-item you update or add to the database
- "Insert" hotkey is added to the Genres, Actors, Sites windows to open adding interface
- new filter buttons, few cosmetic changes, tooltips -
since it doesn't have a search imdb function i assume it's not for mainstream movies. and with all the password/privacy stuff i'd guess it's most likely intended fuction is a porn database.
Videonizer has been updated to version 2.3.0.5
v2.3.0.5- new "File types to support" button is added to the Settings window; allows you to customize Videonizer's extensions filters
- a bug is fixed when deleted screenlists and photos still remained in the database physically -
Videonizer has been updated to version 2.3.0.7
v2.3.0.7- full-screen size support is added (click on the "maximize" box near the "close window" box)
- new "5-stars" rating system
- the main window size choice is stored and used during startup
- few cosmetic changes -
Videonizer has been updated to version 2.3.0.9
v2.3.0.9- support for small screens is added -
Videonizer has been updated to version 2.4.0.1
v2.4.0.1- "Delete physically" option is added to the items context menu
- a "middle mouse button" click on an item will open corresponding video-file with your system default video-player
- video information module is updated
- database info section is redesigned -
Videonizer has been updated to version 2.4.0.2
v2.4.0.2- new "File Name" filter allows you to filter the list of files on the fly (case-insensitive)
- "CTRL+ENTER" hotkey is added to open selected file with your system default video-player (as an alternative to middle mouse button) -
Videonizer has been updated to version 2.4.0.3
v2.4.0.3- "CTRL+ENTER" over a group of items sends a playlist to "the first external video-player" (that means to the first player in the list of available players for the first selected item of the list)
- if you want to choose a particular player to open a group of items - use right mouse button to call a context menu and choose a video-player to play the playlist
- Minimize/Restore bug for small notebook screens is fixed
