VideoHelp.com Forum
  1. Pioneer DV-C503 Stopped Playing CD/VCD Still Plays DVD's. On startup it spins up with the display showing loading, then all of a sudden it switches to open and pops the tray open.
    It wont play and VCD's even old ones that worked fine. Also wont play any music CD's anymore including store bought.
    Any clues?
    (Player is only 13 months old)
  2. maybe it's possessed?
    sorry for that smartass comment, couldn't resist, i mean, the tray opening up by itsef isn't normal. i have no clue what the problem could be,i'd say that maybe the lens is scratched but if it still plays DVDs, that's not the problem. you're probably best off contacting pioneer support for your problem, if it's bad enough, you could probably get a free replacement.
  3. I had the exact same problem on my Apex 660...Out of the blue it stopped playing my vcds..Dvds still played fine. VCDs would give me a "no disk" error...I opened it up and cleaned the lens with a q-tip and some tape head cleaner i had. After that all was well and it once again plays virtually anything I put in it. Dont waste your time with those cleaning kits that have a cd with a little brush glued on it. They have never worked for me.
    Good luck, hope this helps.
  4. It's been opened and cleaned well so thats not it. :(
  1. My Unlocked Phillips dvp3980 has suddenly stopped playing AVI files?
    By UmmAddan in forum Newbie / General discussions
    Last Post: 10th Mar 2012, 11:58
  2. medial player stopped playing my movies
    By CheekyKid in forum Newbie / General discussions
    Last Post: 20th Jan 2010, 00:26
  3. Windows Media Player stopped playing .mov files
    By dzsoul in forum Software Playing
    Last Post: 18th Mar 2009, 23:29
  4. Panasonic DVD SA-HT743 stopped playing Original DVDS
    By chankya in forum DVD & Blu-ray Players
    Last Post: 23rd Dec 2007, 16:38
  5. First Generation Philips 642 Stopped Playing DVD+R DL
    By somebodeez in forum DVD & Blu-ray Players
    Last Post: 4th Sep 2007, 16:57
