Recently capture video via NIKON D90, it is snap under low light condition. But after play back, it appear black and white layer continues moving from bottom to top of the clip. What wrong with it? How to fix it?? Check my clip out at - http://www.youtube.com/watch?v=fZKuN9_Izoo
Thank you!
1. What is "snap"?
2. It's probably fluorescent lighting in your room. -
I dont think so my camera have this setting. What is this anyway? The problem only appear in under fluorescent light...
1) How to avoid this problem?
2) I need to edit my video, any idea how to fix my post video clips?
Please help.....
Thank you. -
The problem is that the lights are strobing at what frequency your electrical system runs at (generally 50Hz or 60Hz), and your camera is picking this up. Some cameras have a setting that allows them to match the frequency so you don't get this effect. If yours doesn't have such a setting then you really only have one choice - don't use fluorescent lighting, or use brighter standard lighting so your drown out the flouros.
Read my blog here.
Whats wrong with this batch Mkv script?
By Animebuster in forum EditingReplies: 0Last Post: 21st Jul 2010, 03:59 -
Audio that use to play wont anymre. Whats wrong?
By UmmAddan in forum Software PlayingReplies: 1Last Post: 5th Jan 2010, 18:13 -
All was well ...then whats the hell wrong with the sound
By qwerty00000 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 26th Sep 2009, 05:39 -
Silent frames and/or wrong clip start with Movie Maker
By fvisagie in forum EditingReplies: 0Last Post: 18th Aug 2009, 07:55 -
Whats Wrong With This Forum?
By gealto2 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 27th Jun 2007, 18:11
