Hi guys...
I muxed .mkv videos with subtitles using mkvmerge to make softsub video file.when i play this on my sony blue-ray player,i cant forward/rewind the movie,it hangs.but when i do the same muxing for .avi/.mp4 files,no problem in forwarding/rewinding it.pls help me out as lot of my movie collection are .mkv.
Thread: Muxing with mkvmerge
Try enabling the "disable header removal compression..." option and remux.
@jagabo:I can forward/rewind now after trying ur suggestion.but the video is distorted in every 5min intervals(like when we press slow motion button).
PS:-I had this prob b4 trying ur suggestion also. -
Because it's not using compatible settings . Usually what you describe is caused from long keyframe interval . It needs to be re-encoded.
mkvmerge muxing shortens duration of video
By Torky in forum Video ConversionReplies: 2Last Post: 20th Apr 2012, 22:20 -
Batch subtitle muxing - mkvmerge
By mkr10001 in forum EditingReplies: 1Last Post: 18th Feb 2012, 12:03 -
Correct way of muxing subtitles with mkvmerge
By zammil in forum SubtitleReplies: 3Last Post: 4th Jan 2011, 04:29 -
MKV Muxing / MKVmerge GUI 4.4.0 / The KMplayer 2.9.4.1435
By stanfield in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2010, 04:36 -
Muxing MKV file with mmg (mkvmerge)
By HAL4711 in forum Newbie / General discussionsReplies: 4Last Post: 9th Jul 2009, 18:49
