hi
i use aimersoft to convert my m4v to avi so that i can play them on mine dvd player
i want to make a perfect conversion with sim quality but havent managed it
something is always off
the avi's have to 720 x 480 max otherwise mine dvd player wont play them
is there a way to convert the m4v to 720 x 480 avi with the same quality
i am still learing to use aimersoft i would appreciate any advise on setting ect
so i can make same quality avi's from m4v
"avi" is the name of a container. it can hold many different types of video. i assume you mean divx? as in you have a dixv capable dvd player?
if you have m4v videos, where did they come from? most likely they have already been re-encoded from something else into a iThing format? re-encoding them again is only going to make them look worse.
post the mediainfo from one of the m4v. it's free, set it to the text output and copy and paste it here.--
hi
sorry it took so long busy weekend
Formaat : MPEG-4
Formaatprofiel : Base Media
Codec-ID : isom
Bestandsgrootte : 1,45 GiB
Duur : 22mn 39s
Totale bitrate : 9 151 Kbps
Datum codering : UTC 2011-08-26 19:25:35
Tagdatum : UTC 2011-08-26 19:25:35
Video
Formaat : AVC
Formaat/Info : Advanced Video Codec
Formaatprofiel : Baseline@L3.0
Formaatinstellingen, CABAC : No
Formaatinstellingen, ReFrames : 1 frame
Muxingmodus : Container profile=Baseline@1.3
Codec-ID : avc1
Codec-ID/Info : Advanced Video Coding
Duur : 22mn 39s
Bitrate : 1 545 Kbps
Breedte : 632 pixels
Hoogte : 354 pixels
Beeldverhouding : 16:9
Frameratemodus : Constant
Framerate : 23,976 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
Scansoort : Progressief
Bits/(Pixel*Frame) : 1.348
Stroomgrootte : 1,43 GiB (99%)
Taal : Engels
Audio
Formaat : AAC
Formaat/Info : Advanced Audio Codec
Formaatprofiel : LC
Codec-ID : 40
Duur : 22mn 39s
Bitrate-modus : Constant
Bitrate : 96,0 Kbps
Kanaal(en) : 2 kanalen
Kanaalposities : Front: L R
Samplerate : 44,1 KHz
Stroomgrootte : 15,6 MiB (1%)
Taal : Engels
Question about settings for convert movies in divx/xvid to m4v or mp4
By Marcelo_Ramone in forum Newbie / General discussionsReplies: 1Last Post: 12th Sep 2011, 09:25 -
M4V vs. AVI
By mkr10001 in forum Video ConversionReplies: 10Last Post: 29th Apr 2010, 10:03 -
M4V to AVI or MPEG??
By Nikolaiwww in forum Video ConversionReplies: 7Last Post: 5th Oct 2009, 05:38 -
aimersoft mkv conversion problem...
By freewheelin in forum Video ConversionReplies: 1Last Post: 6th Sep 2009, 13:22 -
VirtualDub -> Handbrake m4v, audio settings?
By milltone blabbit in forum AudioReplies: 5Last Post: 30th May 2009, 22:33
