Results 1 to 10 of 10
    Feb 2009
    hope this is in the correct place
    DIY TELECINE BOX FOR
    SUPER 8 CINE TO DVD (HOME MADE)
    i made this as direct from a projector screen was not good enough.
    HOME MADE TELECINE BOX TO TRANSFER CINE TO DVD
    MADE FOR UNDER 10...
    use pre made box or make one from cardboard realy simple,use front reflection mirror, black out the inside of the box, see diagram at start of the video ...
    http://youtu.be/Pc-zhILQcoY
    feel free to ask any questions about the project.
    hope it helps someone
    vcdeasy???
    Feb 2009
    whats that got to do with what ive posted?
    its me showing what ive done,
    not realy relevent to what ive posted.
    its direct to dvd & not being edited,(direct to dvd recorder)
    your post aint Realy helpfull
    You posted in the VCDeasy section....
    Feb 2009
    ok thats why i put (hope this is in the correct place)
    can it be put in the correct section as i couldnt see one for cine film?
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Moving to capturing forums section.
    Feb 2009
    thanks
  8. Hi
    Thanks for sharing that video.
    Of what material is the viewing screen? Is that some kind of fabric or semi-opaque glass...?
    GG
    Feb 2009
    Originally Posted by Groami Geistalt View Post
    Hi
    GG
    it was just some polly/plastic sheet i had laying around, its about 400 micron thick, but you could try a glass frosting spray paint from most craft shops/DIY store & spray an old small picture frame glass from the likes of the dollar/pound store.
