    Jan 2006
    Hi, I'm looking for a software to go with my new USB capture device I got from StarTech. It came with a program called GrabBee, but I've noticed that the quality's not too great, even capturing at 8200kbps, i still get weird frames (especially due to interlace) where if I try to deinterlace it, the fields always get blended due to the low quality of the interlace lines.
    And I've tried to see if it would work with other softwares, but a lot of them can't detect by USB device.
    So I was wondering if anyone knew a good device? Preferably that allows me to capture into DVD MPEG2 format?
    Oct 2005
    666th portal
    see if virtualdub can find the device. there is a plugin for mpeg-2.
    Jan 2006
    VDub doesn't recognize it
  4. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Power Director 8/9 will recognize flawless. Record in MPEG2@25000 bitrate.
    Claudio
  5. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Plugin to record MPEG2 in VD??
    Tell me.
    Claudio
    Oct 2005
    666th portal
    my mistake, the capture portion doesn't use the plugins... i always used powerdirector to capture to mpeg-2 if that was what i needed.
    if you install the Cedocida dv codec it should at least get you to DVavi with virtualdub capturing.
    Sep 2012
    Montreal
    VLC 2.0.3 can detect the StarTech SVID2USB2 device. I got far better results than GrabBee by using VLC's MPEG-2 even at 6000 Kbps. And all this was done on my cheap laptop (Gateway NE56R, Win 7 Familial Premium x64, Intel Celeron CPU B820 Dual-Core 1.7 GHz with only 4 Gb RAM, USB 2.0 port).
