Try this simple fix: Control+Alt+Delete to start Task Manager, then End Program. Restart capture software.
My story--Diamond One Touch VC500 capture device, trying to get movies and HBO episode series onto DVD's. (Many cable companies won't allow TiVo to transfer these to computers--they copy protect them. Grr!)
The device works well. I'm not doing much other than cutting out the beginning and ending of shows, which Windows Movie Maker works fine doing. I also tried Adobe Premiere Elements, but had synching issues with audio and video.
My Settings: NTSC_M_J, DVD quality, S-Video input
Hope this helps someone!![]()
Results 1 to 1 of 1
TMPGENC 4.0 Xpress Weird Problem! (Shows Green Bar On Left Side Of Video)
By hypnoticpimp in forum Video ConversionReplies: 16Last Post: 11th Jan 2010, 07:36 -
By hypnoticpimp in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2009, 02:17 -
By hypnoticpimp in forum Authoring (DVD)Replies: 1Last Post: 14th Apr 2009, 09:05 -
green vertical bar on left, purple verticle bar on right, source B&W VH
By lipwak in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jul 2008, 21:29 -
Green bar on bottom and right side of divx movie
By gthorley in forum Software PlayingReplies: 2Last Post: 19th Aug 2007, 14:39
