I have noticed that VirtualDub now ships it's de-interlace filter settings defaultly set to "yadif". What is that? When did it show up? Is this better than "blend"? It looks nice but I can't tell. Are my eyes really seeing a nicer picture? Am I doing something less natural than just blending the two fields together? I think that I can see the improvement on overlay things such as the date in the corner of the video. Should I stick with Blend? Is it better enough to make me want to go back and redo some work I've already considered finished?
I am only working with Home video shot on Video8 and VHS. I've been converting them to Xvid. I try not to get over complicated and keep it simple.
Capture 640x480 29.97fsp raw YUY2. 44.1k PCM Audio. I capture at 480 lines to ensure both feilds are snagged from the BT8xx chip.
Load up the capture file, chop out the noisy edges of the video, and simply add a de-interlace filter. I've always just been using "blend"
Then default settings for Xvid codec and LameMP3 CBR 128k bitrate and let it encode.
Any advise about the deinterlace choices? Any other advise?
Thanks,
-Kreg
Blend blurs the two fields together. Look at a frame where there's lots of motion. Blend will look like a double exposure. You'll also see a loss of vertical resolution over the entire frame. Yadif attempts to only deinterlace parts of the frame where it detects comb artifacts. It usually gives better results, a sharper picture overall, but can lead to jagged artifacts on near horizontal edges, buzzing when there are small motions.
Haali Media Splitter performing blend deinterlace...?
By genak in forum Newbie / General discussionsReplies: 1Last Post: 21st Jun 2011, 06:32 -
Deinterlace and reencode with bdrebuilder+ffdshow+yadif at 60fps
By dinobike in forum Video ConversionReplies: 2Last Post: 30th Aug 2010, 13:59 -
Slo-mo & frame blend, deinterlace, flicker, export settings, lions, tigers
By ivanarias in forum EditingReplies: 3Last Post: 24th Feb 2010, 22:35 -
vdub "blend" deinterlace works, but now lines are jagged
By italo4ever in forum Video ConversionReplies: 3Last Post: 29th Jun 2009, 22:35 -
VirtualDub Smart Deinterlace filter vs Xvid option
By StealthKing in forum DVD RippingReplies: 16Last Post: 17th Aug 2007, 11:37
