    Jul 2011
    Erlanger Ky
    Hi There,
    Yes i'm new to video but not to imaging in general as I've been a still shooter for quite some time.
    So a videographer friend of mine told me to download MPEG Streamclip for Mac in order to transcode
    video to edit in Final Cut Express. So I've done that but I cannot find " Apple Prores 422 " within the listing
    of export formats which he is telling me to transcode it to.
    Am I missing something???
    -blanco-
    Oct 2005
    666th portal
    thread should be moved to mac section for a better chance of a mac user's answer. but i think prores422 is a codec that only comes with final cut pro.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    FC Express can capture direct to AIC (Apple Intermediate Codec).
    What is the source format? AIC is an 8bit 4:2:0 codec better matched to most consumer and prosumer formats.
    ProRes422 is 8bit or 10bit 4:2:2 sampled. 4:2:0 source goes through a lossy resample.
    Keep in mind that DVD and Blu-Ray are 4:2:0.
    http://www.kiva.org/about
  4. Member Cornucopia's Avatar
    ProRes 422 Encoder only comes with FCP/FCS (mac only $$), or with DVS Clipster (turnkey only $$$$), or with Telestream's encoders (Vantage/Episode/etc - Mac & PC $$$), or using hardware encoders such as AJA or others ($$$).
    Decoder now comes included free with QT as of version 7.6.6 or higher (PC & Mac).
    ProRes 4444 is still a problem on the PC (no decoder only, just those costly options mentioned above.
    *Note the encoder DOESN'T come with FC Express (or iMovie, for that matter).
  5. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    This thread is probably better in the Mac Forum. Moving you.
    This is the answer.
