I have a few Internet streams that I enjoy that are RTMP and rtmpdump seems to successfully "dump" them.
The only problem is I am not having much luck trying to get more advanced.
So far I can easily make a batch file to record.
What I'm trying to do is have a batch file record what I want, give it a date/time in it's file name, reconnect if disconnected, and then stop "dumping" when the program is over.
So far I'm having the most problems with reconnecting if disconnected and how to stop it after say an hour.
Try StreamFab Downloader and download streaming video from Youtube, Netflix, Amazon! Download free trial.
Use the Task Scheduler to run your batch file at a particular time. Use the SET command in your batch file to create a filename from the date and time:
set FILENAME=%date:~4,2%-%date:~7,2%.flv
RTMPDUMP yada yada yada -o %FILENAME%
RTMPDUMP to download BBC video from outside the UK
By vor12 in forum Video Streaming DownloadingReplies: 16Last Post: 11th May 2012, 13:40 -
download siriusxm stream with rtmpdump error
By MUSICFAN189 in forum Video Streaming DownloadingReplies: 2Last Post: 30th Mar 2012, 15:05 -
Req: free(ish) tool to join mp4 stream chunks grabbed with rtmpdump
By grelga in forum Video ConversionReplies: 0Last Post: 18th Nov 2011, 14:33 -
Problem with rtmpdump
By itzkirby in forum Video Streaming DownloadingReplies: 0Last Post: 17th Apr 2010, 17:25 -
Panasonic TOUGHBOOK 19 Notebook, won't reconnect to net after being closed
By Denvers Dawgs in forum ComputerReplies: 2Last Post: 15th May 2007, 05:01
