hey, ive recently got a blackmagic intensity pro and have tried to capture xbox 360 gameplay. the video quality was fine but i began to experience audio latency, i have no idea why and would like to know if i need to upgrade or my settings are set wrong. in a nutshell i have no idea whats wrong :/
You dont' specify what you're using for capture settings so it's hard to tell what you're really running into. From your computer specs, I'm guessing you only have a single hard drive (350gb?) and are probably dropping frames as you capture.
Here's what I'd recommend:
- Get a second hard drive just for capturing, keep it defragmented.
- Make sure you don't have unnecessary processes running in the background.
- Set your 360 output to no more than 720p
- Capture MJPEG, 720p
If you're like others and want to post to youtube or send it to friends and need to shrink the size - take the output file and re-encode (you will lose some quality) to divx/xvid CQ3 retaining 1280x720 or h264 (via x264vfw) CQ 20 and MP3 128k audio using VirtualDub.Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
Thanks neomaine ive just discovered my pc has 2 500gb hard drives one full of my stuff like games ect and the other blank, i have tried to use this second hard drive to capture in 720p MJPEG but it is still dropping frames, a guy at blackmagic design help centres said i should setup my hard drive to raid? and use capture uncompressed and was wondering what to buy in order to do this and if so what and how to do it thanks
your best bet would be to buy 2 new fast sata drives(w.d. black or samsung f3) and a raid controller card and set it up as raid 0. raid 0 stripes the incoming data across both drives for faster writing, allowing for uncompressed video capture.
iirc blackmagic support has a list of the ones they like.
Blackmagic Intensity Pro Help.
By MoonVid in forum CapturingReplies: 1Last Post: 4th Nov 2011, 16:10 -
Blackmagic Intensity Pro.
By liamb96 in forum CapturingReplies: 8Last Post: 18th Oct 2010, 16:20 -
Blackmagic Intensity Pro 3.5.1
By Lynas in forum CapturingReplies: 24Last Post: 10th May 2010, 13:28 -
Blackmagic intensity pro help
By Smify123 in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2010, 11:19 -
BlackMagic Intensity Pro
By Richintx in forum CapturingReplies: 0Last Post: 23rd Jan 2010, 09:43
