I used a software, Ripit, on a DVD. Usually I'm used to getting a TS file.
I chose this time to compress and rip, (instead of going through popcorn)
This time it gave me a huge 6gb DVD media player document, and also a small .m4v which is 2GB so I'm totally confused. And the .m4v says protected which defeats the purpose of the software.
What are these files? How would one deal with them with Toast. thanks!
PS When did toast 11 come out? and when is Toast 12 projected to come out. thanks.
Results 1 to 9 of 9
Thread: What is .m4v?
.m4v info from Wikipedia: http://en.wikipedia.org/wiki/M4V More often associated with iTunes and DRM protection.
Ok, so it wont burn into a DVD, and it has copy protection.
can you at least get it to play? try changing the extension to .mp4 anyway? perhaps a screen cap would suffice
Author, Producer, Composer, Director - Sony HDV, Konica SLR, LG BD burner
Handcoder: HTML, PHP, JS, CSS - In Production: Busker Alley - The Movie -
Well, MPEG2 (for DVD SDTV) is lower quality than MPEG4. If the MPEG4 (which is from iTunes) isn't copy-protected (and the ".m4v" doesn't necessarily mean there's DRM even if a "get info" says it's a copy-protected file; sometimes simply changing the extension to "mp4" is fine), authoring it to BluRay requires the appropriate software and hardware (a BR burner and Toast with the optional add-ons or some other app). But the quality of the iTunes video won't be any better than what it is right now.
Instead of authoring/burning to a disc, why not simply use an inexpensive media player (like the WDTV)? That eliminates the need to author/burn and saves time and lots of money.
How to create M4V files w/AC3+AAC from M4V w/AC3 only??
By williamlondon in forum MacReplies: 4Last Post: 5th Oct 2010, 16:15 -
M4V vs. AVI
By mkr10001 in forum Video ConversionReplies: 10Last Post: 29th Apr 2010, 10:03 -
M4V Timecodes?
By Penumbra in forum Video ConversionReplies: 5Last Post: 2nd Apr 2010, 16:21 -
m4v to DV
By jscape2000 in forum MacReplies: 3Last Post: 3rd Dec 2009, 12:41 -
m4v to dvd
By Prot in forum MacReplies: 2Last Post: 28th Oct 2009, 10:00
