Hi,
I have PAL 720x576 formatted VOB file.
Display aspect ratio is set to 16:9
I want to extract frames from this file with size 720x405.
I can specify the size in ffmpeg while extracting. Is there
any other way to extract the frames with this resolution?
Do I need to change VOB header somewhere?
Regards,
Omkar
Results 1 to 11 of 11
What I essentially want to do is set aspect ratio of the VOB file to 16:9 720x405 without reencoding the video.
VirtualdubMod can open your VOB, you apply the resize filter to output 720*405. Save "image sequence" as bmp and later convert your files to jpeg
ffmpeg -i video.vob -vf scale=720:405 -qscale 1 image%04d.jpg
The command will obviously generate a lot of files, so it would be a good idea to create an empty folder for the conversion.
'-qscale' controls the quality (and filesize) of the jpeg images. A lower value = higher quality (bigger jpegs).
The formatting of the image filenames can be changed:
'image%04d.jpg' will create jpegs with the filenames image0001.jpg, image0002.jpg, image0003.jpg
'image%02d.jpg' will create jpegs with the filenames image01.jpg, image02.jpg, image03.jpg
'image%08d.jpg' will create jpegs with the filenames image00000001.jpg, image00000002.jpg, image00000003.jpg etc
You can also output png, tga, tif images by changing the extension:
image%04d.png for example. -
Ok, What changes should I make to the header so that any player will stream it as 720x405?
You can change the aspect ratio of a VOB file to 16:9 without re-encoding, but that doesn't involve changing the resolution - the resolution will still be 720x576.
You're asking several different questions. What is your end goal?
Do you want to create a directory of jpeg images from a .vob file? Or simply change the aspect ratio of a vob without re-encoding it? -
Hi, my end goal is to create directory of jpeg images of size 720x405 from vob.
This can be done using ffmpeg scaling parameter as you have shown.
Can I change the VOB aspect ratio and not use ffmpeg scaling parameter?
Meaning, after I fix VOB AR flags if I run
I get images of size 720x405? -
I don't think ffmpeg will do that.
I've just experimented with a couple of VOB files. One is 4:3, the other is 16:9 (both are the same resolution - 720x576). In both cases ffmpeg outputs images with the same resolution as the original VOB files (720x576). The scale filter is the only way I've found to force a custom resolution.
Also, if your VOB file is interlaced, you might want to add the yadif filter to deinterlace the video and avoid jaggies on the outputted images:
ffmpeg -i video.vob -qscale 1 -vf yadif=0,scale=720:405 image%04d.jpg
It should be possible to use 'yadif=1' and output one image for each video field. However this doesn't seem to work when outputting images - only 'yadif=0' works as expected (one image for each pair of fields).
Extracting subs/frames in 200 DPI
By user2008 in forum SubtitleReplies: 1Last Post: 9th Sep 2010, 10:39 -
Extracting frames
By tomblyn in forum Video ConversionReplies: 5Last Post: 28th Jan 2010, 07:01 -
Extracting Frames From Video Takes Forever
By FOBOS in forum ffmpegX general discussionReplies: 0Last Post: 14th Apr 2009, 11:20 -
Extracting jpg frames from Video files
By wrazoru in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2008, 05:08 -
FFMPEG: Extracting multiple frames at different intervals
By roden in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2007, 11:35
