Results 1 to 15 of 15
    Jan 2002
    I already have a Popcorn Hour A-110 and I really don't like it. So I'm not really interested in the new version.
    I started buying Blu Ray movies last year. But I've held off on buying a Blu Ray player because I planned pn buying a new media player. The problem is the only player (as far as I can tell) that plays Blu Ray isos with full menu support is the Dune player. And the price on that seems pretty ridiculous. Maybe I'm just going to have to bite the bullet and overpay for one.
    But I was just wondering if there is a media player out there that will allow me to play Blu Ray .isos with full menu support. And surround sound. From a usb hard drive.
    Jun 2011
    Have you tried Oppo?
    http://www.oppodigital.com/
    Jan 2002
    Thanks for the reply. I did check out the site. But I'm looking for a media player like WDTV, etc.
    Plus, the cheapest unit there was still more expensive than Dune and the most expensive was nearly 3 times the price. Totally out of my price range.
    I haven't also seen any other player then dune (like http://www.mediasmartserver.net/2011/01/19/review-dune-hd-smart-d1-media-player/ ) with blu-ray iso menu support.
    Maybe you could build a cheaper HTPC.
  5. The Dune does not support menus for BR iso. It does for BR folders
    Least that's what the review baldrick linked to
    BluRay ISO (main movie only) – played without issue (PASS)
    BluRay Folder(entire disc) – played movie with full menu support (PASS)
    DVD ISO and/or Folder Structure – played with full menus (PASS, also appears an issue with audio stuttering has been corrected)
    Originally Posted by jagabo
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Then does noting support bd iso menus?
  7. Hdx bd1
  8. Both the media payer chipset companys (sigma +realtek) are about too(sigma), or have(realtek) released new versions of their core chipsets. I have heard that new players based on these new more powerful chipsets are due out "real soon".
    Another rumor is that the sigma chipset will support java and flash which are both pre-requisites for blu ray menus.
    This is all "about to be released" so YPYMYTC, YMMV etc. I am waiting to see what WD (and others) can come out with based on these Chipsets. If their not up to scratch then HTPC for me. Actually its probably HTPC for me anyway..
    The electronic components of the power part adopted a lot of Rubycons.
    Dec 2008
    Australia
    On NeoTV550 BD ISO with menu navigation is supported http://www.havetheknowhow.com/Hardware-reviews/Netgear-NTV550-Review-page3.html
    May 2010
    Australia
    Not true. I have a Dune HD Base 3 and play BD ISOs which have menus. I have yet to find a way to play 5.1 audio through my audio unit via the TV, however.
    Jul 2001
    Via the TV? Good luck with that. Most TVs will only pass through 2.0. You'd need to go to the audio unit first or split the video and audio to TV and 'audio unit'.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
    May 2010
    Australia
    My TV is connected to my sound system via optical cable. If I connect my video camera to a HDMI port on my TV, I can play surround sound through my sound system, thus proving that it can be done. I am taking the matter up with Dune support (wish me luck!).
    Jun 2008
    Dafoe:
    I have read about MediaMatchBox player from Crystal Acoustics. It supports BD iso but I am unsure about the full menu support. Check it out.
    Jul 2001
    Your camera can record and output 5.1 sound? Doubtful. I'm betting it's just your sound system using VSS while getting 2.0 stereo.
    Have a good one,
    neomaine
    May 2010
    Australia
    A belated reply:
    I got nowhere with Dune. They just told me to play around with cables, and didn't accept that it was a problem with their gear.
    And yes, my camera can record in 5.1 audio (or stereo if preferred). (Sony HDR-XR520)
    I even used my video editing program to create a test video with sound on each channel, one at a time, which I then downloaded to my camera and played back through my system, to verify that it was truly playing back in 5.1
