I have a piece of software that I'm using that accepts AVI files. However, it will only accept AVI files that have 24-bit color depth. Most AVI files have a color depth of 32 bits. Is there some sort of software program, preferably free and user-friendly, that will allow me to convert a 32-bit AVI file to a 24-bit AVI file? I'll be working with lots of files, so I'm hoping that the program will be simple and fast. Is there anything like this out there? Thanks so much for your help.
Results 1 to 1 of 1
Dolby Digital Audio bit depth = 16 bits??? Why?
By Bonie81 in forum AudioReplies: 6Last Post: 12th Jun 2011, 21:44 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40 -
8-bit color RGB versus 10-bit color 4:2:2
By fouronthefloor in forum CapturingReplies: 4Last Post: 9th Oct 2010, 06:20 -
Change Color Depth 24bits to 12bits
By PBoy in forum Video ConversionReplies: 6Last Post: 6th Jul 2009, 13:05 -
Xvid 8 bit color depth resoultion problem
By afcoff in forum Video ConversionReplies: 4Last Post: 23rd Feb 2009, 23:50
