So,
after 12hrs of reading...
Clean install....
I have finally found a maybe suggestion to whats wrong..
The problem.
I have connected my Video 8 camcorder to the shuttle (which was also used to record the media)
via composite video with a good RCA cord.
When i am in camera mode it is perfect and records great.
However i want to capture my old Video 8 tapes onto the computer (lossless)
When i turn the camera to video and press play, the capture screen "flickers" badly. I see empty screen, then video, then empty screen and so on. It is totally useless...
I thought it was nec drivers then the shuttle drivers etc,
What i have learned is it might be that the Tape has time base error and i need a TBC time base corrector??
What is wrong?? i thought this was going to be easy with the blackmagic shuttle and my new computer...
Do i get a new capture card?
Do i get a new TBC? and can u get them to Capture into the computer?
Do i get a second hand video 8 camcorder off ebay?
ARRrg
I have got a reply from Blackmagic:
Quote strted:
Thank you for contacting us. Usually in this case if the signal from your
Video 8 is spotty then you would need to add a sync source to this in order
for it to capture properly.
VHS machine composite output can vary widely in its sync level quality - if it’s a high grade VHS player AND tape source it will be fine, if not then perhaps try a cheap VHS dubbing box.
Try SVideo out from your camera along with composite
Use SVideo input in shuttle (dummy composite will probably will give it the sync)
Use red and white Audio.
Quote ended.
Can i ask whats a sync source? is this like the time base corrector?
Is the Video 8 now VHS? Or have they got it wrong or is it the same format?
A cheap dubbing box? Again i don't really know ??
I really dont know what i need now.. -
Sounds like they are recommending a TBC, don't know why they talked about VHS, possibly additional info or a mistake in copy/paste.
All analog tape based formats have time base errors. If that's what causing the problems with the Intensity Shuttle a TBC should help. In my opinion any analog capture device should be able to tolerate the average time base error on VHS or Hi8 tapes.
I got the intensity shuttle for Thundebolt. I use it to capture from the LaserDisc player which outputs composite to Panasonic DMR-ES25 DVD Recorder (for motion adaptive 3d comb filter) which in turn outputs component to Blackmagic Intensity Shuttle for Thunderbolt. I am informing everyone that it can drop up to 8 frames without informing the user. When you capture any video, how would you find out that the frames are dropped if you are not informed about it? But I was simultaneously capturing from my LD player using S-Video into Diamond VC500. And also after that I would capture into ATI HD 750 PCIe. Captures using VC500 and ATI HD 750 PCIe perfectly matched. But captures using BM resulted in lost up to 8 frames. One time I lost 8 frames, 2 times I lost 4 frames, other 2 times I lost 2 frames and one time I lost 3 frames. There were a couple of times that I didn't lose any frames. I just informed BM support about it. But in case you want to get this device, be aware. Another thing is audio is kept in sync. I.e. when I was short 8 frames, the audio was short by approximately 250 milliseconds.
Blackmagic Intensity Shuttle use with Laptop
By SkinnyRabbit in forum Capturing and VCRReplies: 28Last Post: 12th Dec 2011, 22:43 -
Blackmagic Intensity shuttle.....no video
By REDRUMxINxTX in forum Capturing and VCRReplies: 6Last Post: 9th Nov 2011, 16:56 -
BlackMagic Intensity Pro/Shuttle
By Wile_E in forum Capturing and VCRReplies: 8Last Post: 17th Mar 2011, 15:14 -
Problems with detecting my Blackmagic Intensity Shuttle
By Arceopteryx in forum Capturing and VCRReplies: 0Last Post: 22nd Jan 2011, 03:40 -
Q for people who have Blackmagic Intensity Shuttle
By SkinnyRabbit in forum Newbie / General discussionsReplies: 1Last Post: 2nd Nov 2010, 19:07
