I've got a video lecture, about 1 hour 20 minutes long. The sound was either recorded from the back of the room or the room had terrible echo acoustics. The lecturer is really hard to understand because his voice comes across with an echo.
Might there be some way that I could remove the sound echo in the video so that I can clearly understand it?
There is NO way to do this without:
1. Lots of Time & Expensive!! software
2. Great understanding of how to use them & how NOT to use them
3. BOTH
Even then, there's a very good chance it won't come out how you want it.
If you have to have a good copy, I would suggest:
1. REDO the lecture, this time record it better
2. Re-record a good copy of the audio (maybe doing it yourself), editing it to be in sync with the video
Scott -
Also, perhaps post a 15 second clip for a further opinion.
Would like to remove or at least reduce wind sound from M2TS video
By kmw in forum AudioReplies: 5Last Post: 11th Nov 2010, 19:06 -
Echo-like sound in avi file
By avoidz in forum AudioReplies: 7Last Post: 17th Sep 2010, 09:46 -
My Philips DVP 5140 has an annoying echo sound
By Amuse in forum DVD & Blu-ray PlayersReplies: 3Last Post: 26th Sep 2008, 10:55 -
remove echo from vcd?
By sharmine in forum AudioReplies: 1Last Post: 15th Nov 2007, 06:31 -
FLV sound with echo in Safari
By EdVD in forum Video ConversionReplies: 0Last Post: 17th May 2007, 11:02
