Results 1 to 16 of 16
    May 2011
    Paris (France)
    Hi,
    I just have changed my OS from XP 32 bits to win 7 64 bits, and i'm a bit lost with editing videos in Virtualdub.
    I have chosen :
    - the 32 bit version of Virtualdub with the following plugins :
    • DirectShow
    • MPEG-2
    • WMV
    • FLV
    • QuickTime
    • FLIC
    • AC3
    - the 32 bits mega version of K-lite codec pack.
    - avisynth 2.6 32 bits
    In ffdshow vfw configuration ,I've set the wmv1/7 , 2/8 , 3/9 ,vc-1 to wmv9 instead of disabled.
    With this, I can edit :
    -the WMV video, I have to select the file first then select the Windows media files from the the dropdown menu
    -the mpeg-ts (mpeg2 ?) videos, I first have to write an avs script like this : DirectShowSource("H:\Total Média\****.mpg") and then drag and drop it in Vdub
    The third type of videos I need to edit is the flv files. I am really confused between the settings of vfw ffdshow codecs and Win7DSFilterTweaker. I want to change a minimum of parameters to keep the easy way to open my wmv and mpg videos
    Here is the mediainfo report :
    General
    Complete name : F:\Docs Win7\StreamTransport\***********.flv
    Format : Flash Video
    File size : 621 MiB
    Duration : 58mn 27s
    Overall bit rate : 1 484 Kbps
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=3, N=33
    Codec ID : 7
    Duration : 58mn 27s
    Bit rate mode : Constant
    Nominal bit rate : 1 350 Kbps
    Width : 640 pixels
    Height : 360 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.234
    Color primaries : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM
    Transfer characteristics : BT.470-6 System B, BT.470-6 System G
    Matrix coefficients : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM, IEC 61966-2-4 601
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 10
    Duration : 58mn 27s
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    THX and sorry for my poor english
    Maybe just install FLV Splitter to begin with.
    May 2011
    Paris (France)
    Thanks for helping Baldrick,
    I'm not sure, but I think i did install it already. How can i check this ?
  4. Use the "Files of type" pulldown in VirtualDub's Open Vide File dialog to select "DirectShow input driver". You can also try the "Flash Video files (*.flv)" drier but in my experience it doesn't work with a lot of FLV files.
    May 2011
    Paris (France)
    thanks jagabo,
    Flv splitter is included in K-lite pack.
    Using the "Files of type" pulldown in VirtualDub's Open Vide File dialog to select "DirectShow input driver" will only show avs files. Is that right ?
    If yes, you mean that i have to write a script like this : DirectShowSource("H:\Mes documents\****.flv")
    If yes, it doesn't work.
    I say again that i didn't almost change anything in the settings of vfw ffdshow.
  6. VFW system is not used unless video is AVI wrapped (you have an FLV, not AVI)
    You need FLV splitter and h.264/avc enabled in the ffdshow directshow configuration (not VFW), in order for directshow driver, or .avs using directshowsource() to work
    If neither work, try ffms2 in avisynth
    http://code.google.com/p/ffmpegsource/
    FFMpegSource2("video.flv", atrack=-1)
    May 2011
    Paris (France)
    Thanks poisondeathray,
    I have enabled h.264/avc in ffdshow.
    I'm not sure how to interpret your sentence concerning flv splitter:
    - do have i to enable it in ffdshow directshow configuration ? i.e wich exact line in codec list should i enable ?
    - or do i simply need flv splitter (to install) (already done)
    Anyway i have this bad result :
    "something appears to be stuck while trying to stop ((thread deadlock). abort & exit pgm ?"
    I was trying to open the vid, not to stop it
    Then, I have tried with ffms2 in avisynth and it works well.
    Is there a way to save all this ffdshow settings ? Just in case.
    Nov 2002
    In ffdshow VFW settings...
    H264/AVC .....ffmpeg-mt ....H264,AVC1,X264,VSSH
    FVFW,FFDS
    ....libavcodec .. ffdshow ffvfw internal FOURCCs
    FLV1
    .........libavcodec .. Flash Video (FLV1)
    Theora
    ...... libavcodec ...Theora Video (THEO)
    VP3
    ..........libavcodec .. VP3 Video (VP31)
    VP5
    ..........libavcodec .. VP5 Video (VP51)
    VP6
    ..........libavcodec ...VP6 Video (VP60,VP61,VP62)
    VP6F
    .........libavcodec ...Flash Video (VP6F,FLV4,VP6A)
    VP8
    ..........libavcodec ...VP8 Video (VP80)
    WMV1/7
    ...... wmv9 .........Windows Media Video 7 (WMV1)
    WMV2/8
    ...... wmv9 .........Windows Media Video 8 (WMV2)
    WMV3/9
    ...... wmv9 .........Windows Media Video 9 Simple
    VC-1
    .........libavcodec .. Windows Media Video 9 Advanced
    FFV1
    .........libavcodec .. FFV1 Codec for libavcodec (FFV1)
    Avisynth
    .....Avisynth .....AVIS (Avisynth AVI files)
    May 2011
    Paris (France)
    Hi,
    thanks Darrells for the settings,
    Yesterday, with your advices, I was confident in copping with most of videos format i'm usually dealing with.
    However, something's going wrong with my wmv videos.
    In fact, I just checked editing this video in Vdub, by moving the button along the timeline; this was perfectly working. But I didn't try to simply play the video in Virtualdub. Now, I get this message : No audio decompressor could be found to decompress the audio.
    I have no problem to play this video with MPCHC.
    General
    Complete name : H:\Net Transport\270950_16030_1306853753.AsileKossovars.wmv
    Format : Windows Media
    File size : 4.75 MiB
    Duration : 1mn 27s
    Overall bit rate mode : Constant
    Overall bit rate : 456 Kbps
    Maximum Overall bit rate : 648 Kbps
    Movie name : 3105 DEMANDE D ASILE KOSOVARS-mix
    Performer : France 3 Caen
    Encoded date : UTC 2011-05-31 20:40:54.413
    Copyright : France 3
    Video #1
    Format : VC-1
    Format profile : MP
    Codec ID : WMV3
    Codec ID/Info : Windows Media Video 9
    Codec ID/Hint : WMV3
    Duration : 1mn 27s
    Bit rate : 377 Kbps
    Width : 384 pixels
    Height : 216 pixels
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.182
    Stream size : 3.92 MiB (83%)
    Video #2
    Format : VC-1
    Format profile : MP
    Codec ID : WMV3
    Duration : 1mn 27s
    Bit rate : 177 Kbps
    Width : 384 pixels
    Height : 216 pixels
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.085
    Stream size : 1.84 MiB (39%)
    Audio
    Format : WMA
    Format version : Version 2
    Codec ID : 161
    Codec ID/Info : Windows Media Audio
    Duration : 1mn 27s
    Bit rate : 64.0 Kbps
    Bit depth : 16 bits
    Stream size : 682 KiB (14%)
  10. Now, I get this message : No audio decompressor could be found to decompress the audio.
    for the wma v2 audio in vdub, you need this
    http://www.videohelp.com/tools/DivX_WMA_Audio
    May 2009
    As far as the .flv files go, I have had pretty good success getting that type of file to open in VDub by first opening the .flv in Avidemux and copying the video and audio into an mp4 container. Then in VDub make sure the Quicktime plugin is present, then edit the Quicktime.ini file so that mode=2.
    Qudos to the person who presented that mode setting for the Quicktime plugin in another post a while back. It also allows Zi8 files to open directly in VDub.
  12. Avoid Quicktime at all costs. It is totally screwed up.
    May 2009
    I assume you are refering to Apples Quicktime app., in which case I totally agree. Just for clarity, I'm refering to the Virtualdub Quicktime/MPEG-4 plugin, available here:
    http://forums.virtualdub.org/index.php?act=ST&f=7&t=12664
  14. Originally Posted by JimmyS View Post
    Yes I'm referring to Apple's Quicktime package (codecs and player) or Quicktime alternative (which is just parts of Apple's package, repackaged).
    May 2011
    Paris (France)
    Thanks you for all your answers,
    I installed DivX_WMA_Audio and it works perfectly in Vdub.
    However MPCHC cannot render properly some of the pins (missings codecs). VLC plays this vid with a very poor quality of sound.
    I will try to avoid avidemux, if possible to do all i need in the same program (Vdub). Thx
    EDIT : YEEEEES, Finaly, i tried a second time to compress the audio with AC3-ACM instead of MPEG-layer 3 and MPCHC managed to play with success the video.
