Hi,
I rip my CD's with EAC and LAME (additional commandline: -V0 -q0 -b128) to WAV and MP3, but I recognized that LAME sometimes has 32 kbps in its command line window and sometimes there are only 128 kbps and above. Do I have to worry that all the files I created aren't the "same kind".
In foobar2000 some Mp3 files (only some) it's displyed at the beginning and at the end that the bitrate is under 128 kbps, but only when the file is silent. Strange.
If you look at my LAME settings you'll see that I want Mp3-files with highest quality and minimum 128 kbps.
My Tools versions:
Exact Audio Copy 1.0 beta 1
LAME: lame.exe 3.98.4
Mp3tag v2.48d
foobar2000 1.1.7 beta 2
What do you think? Do I have to worry?
Klaus
Hi,
thanks for your answer. So if I use "-b128" then space is wasted. Did you mean that?
In "switchs.html" is written:
"When used with variable bitrate encoding (VBR), -b specifies the minimum bitrate to be used. However, in order to avoid wasted space, the smallest frame size available will be used during silences."
Is this the only negative effect?
Klaus -
Yes, that's right.
With VBR, LAME will decide what is the best bitrate to use 'on the fly'.
(Explanation here:- http://en.wikipedia.org/wiki/On_the_fly)
Between 32Kbps and 320Kbps.
-V 0 -q 0 gives best results without wasting space.Last edited by bat999; 13th May 2011 at 07:44.
Hi,
thanks for your reply. I want highest VBR quality ("-V0") and highest quality ("-q0") but I don't want Mp3-files that contains parts with bitrates under 128kbps. So for my wishes, the settings are OK. Right?
Klaus
Player with the command line.
By Belini in forum ProgrammingReplies: 2Last Post: 29th Mar 2012, 06:29 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40 -
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 02:23 -
How do I use Lame command line?
By rocky12 in forum AudioReplies: 37Last Post: 16th Jul 2008, 21:33 -
command line
By exekutive in forum ffmpegX general discussionReplies: 22Last Post: 1st Jun 2008, 23:44
