I wonder if one needs to defragment .avi movie files before burning a folder with such files onto a DVD? Or, may be a burning app like ImageBurn actually defrags the file portion by portions in memory before burning these portions, or reads it from hard drive in the right sector sequence so that it's always burned defragmented regardless of the original on HD being fragmented? Any facts (not guessing) explaining the topic would be appreciated.
Also, after burning series of Divx 5 files onto a DVD, a light horizontal line periodically appears on TV screen during playback on a standalone DVD Player. The line divides the screen 1/3 to 2/3, its always in the same place, even if files are different (i.e. when playing a movie serial). The impression is, movie frames are glued in this place. Is it related to file fragmentation, or to incorrect decoding of DivX5 by my DVD Player, or errors in encoding during ripping the original movie from DVD? Any way to get rid of this line - it comes every 10-20 sec irregularly, stays for 5-10 sec then disappears, then appears all over again... No such line, when playing same DVD on PC.
By default, ImgBurn would use both ISO 9660 level 1 and Joliet file systems for such a disc. ISO 9660 level 1 does not allow file fragmentation, thus such a disc would would only contain defragmented files.
Originally Posted by zamar27 -
Thanks. So, where files defrag will be done - in RAM by ImageBurn just before burning read data to DVD? Or ImageBurn simply reads data from HD in the right sequence, so no defrag is required before burning? Just the app buffer size may fluctuate if the file is heavily fragmented, thus requiring heavy HD use to read sequentially?
Are you talking about HDD fragmentation? Imgburn buffers the file in memory and that is used to feed the burner.
Assuming you have a recent PC with a fast hard drive, there shouldn't be any problems burning a disk
unless some other activity causes the drive to thrash when burning. But even then, you would see some
indication on Imgburn's burning screen, such as unable to keep the RAM or drive buffer filled.Last edited by davexnet; 1st May 2011 at 20:40.
Strange artifacts during video playback
By shiningwizard in forum Software PlayingReplies: 0Last Post: 9th Feb 2011, 09:37 -
VHS-C playback issue, playback in B&W and distorted/noisy colour.
By jpoel in forum Newbie / General discussionsReplies: 4Last Post: 11th Aug 2010, 09:36 -
Does Defragmenting help with Burning?
By tbone8 in forum Newbie / General discussionsReplies: 8Last Post: 13th Apr 2010, 15:15 -
Strange artifacts on DVD playback
By polara64 in forum DVD RippingReplies: 6Last Post: 12th Sep 2009, 13:35 -
mac and PC defragmenting differences
By Rudyard in forum ComputerReplies: 9Last Post: 12th Nov 2007, 13:44
