Results 1 to 12 of 12
    Nov 2005
    Is there a way to convert a 3D MKV file into a 2D MKV?
  2. Member Cornucopia's Avatar
    Yes, there are ways.
    Now, what kind of "3D MKV" file do you have?
    Dual-stream? Dual-file? Side-by-side? Top/Bottom? Frame-sequential? Field-sequential? Anaglyph? (If anaglyph, your options are VERY limited).
    Please be more specific...
    Nov 2005
    I don't know how much info you need but I'd say it's side by side.
    General
    Format : Matroska
    File size : 4.02 GiB
    Duration : 43mn 59s
    Overall bit rate : 13.1 Mbps
    Encoded date : UTC 2011-03-30 20:36:07
    Writing application : mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 02:50:32
    Writing library : libebml v1.2.0 + libmatroska v1.1.0
    Video
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=3, N=24
    Muxing mode : Header stripping
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 43mn 59s
    Bit rate mode : Variable
    Bit rate : 11.3 Mbps
    Maximum bit rate : 30.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.228
    Stream size : 3.48 GiB (86%)
    Writing library : x264 core
    Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio
    Format : DTS
    Format/Info : Digital Theater Systems
    Codec ID : A_DTS
    Duration : 43mn 59s
    Bit rate mode : Constant
    Bit rate : 1 510 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 24 bits
    Compression mode : Lossy
    Stream size : 475 MiB (12%)
    Language : English
  4. Member Cornucopia's Avatar
    I'm at work right now, so can't go further into it.
    You could look at the "tutorial/guide" for 3D avi to 2D avi (using AVIDemux), and extrapolate to using MKV. I don't particularly recommend that tute but it'll do.
    If it were me, I'd use an AVISynth script and frameserved into x264 encoder.
    Basically, to keep full quality in the audio, you'll want to:
    Demux to raw streams, leaving the DTS alone.
    Crop to 1/2 frame, and resize to full frame on the video.
    Re-encode the video to best quality of whatever format works for you.
    Re-mux with the saved audio to ? AVI/MKV/MP4, etc.
    If you're going to MP4 Yamb is good, if MKV, MKVtoolnix or AVIMuxGui, etc.
    Nov 2005
    Well I finally got around to work on this yesterday. I used the tutorial for avidemux and it worked well. At first it wasn't able to save the file after the first pass because the audio was DTS. So after that eureka moment I decided to use popcorn to change audio to ac3 first and then work on the mkv with the new ac3 audio. I was trying to use MeGUI but I've never had luck with avisynth. I'm never sure as whether it's installed correctly and always getting an error message there is no function named "Setmtmode". Anyhow thanks.
    Aug 2011
    France
    I would like to convert my 3d MKV to 2D. How can I do this please ? I searched on the Internet and I found nothing.
    The 3D movie I want to convert is a SBS (Side By Side). Han solo1, how to use AVIdemux ? I didn't find the option 3D to 2D in this software
    General
    Format : Matroska
    File size : 4.00 GiB
    Duration : 1h 48mn
    Overall bit rate : 5 285 Kbps
    Movie name : TEAM-3D-FQT
    Encoded date : UTC 2011-06-22 15:06:04
    Writing application : mkvmerge v4.3.0 ('Escape from the Island') built on Sep 5 2010 10:30:51
    Writing library : libebml v1.0.0 + libmatroska v1.0.0
    Video
    Format : AVC
    Format settings, ReFrames : 3 frames
    Duration : 1h 48mn
    Nominal bit rate : 5 782 Kbps
    Maximum bit rate : 40.0 Mbps
    Frame rate : 25.000 fps
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.112
    Writing library : x264 core 106 r1732 b20059a
    Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=fake / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=2 / weightp=0 / keyint=25 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=25 / rc=2pass / mbtree=1 / bitrate=5782 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=vbr
    Language : French
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 1h 48mn
    Language : French
    Aug 2011
    France
    waiting answers !!!
  8. Member Cornucopia's Avatar
    You already got the answers!!!
    Use the AVIDemux tutorial (listed in the turorials section of this site). Use MKV instead of AVI.
    If you need to use AVISynth instead, follow how I suggested in post #4.
    Aug 2011
    France
    Where is the tutorial I am looking for please ?
    Aug 2011
    France
    thanks a lot !!!
  11. @ Cornucopia ,
    hi, i was following your instructions about cropping the 3d 1080p video file in half and then stretch to fit screen but i am unable to do it so far. i was using MKVToolNix v 8.8.0. i cropped the video as "0,0,960,0" but i dont know how to stretch the video to fit the full screen resolution like 1980*1080p,1270*720p etc
    please help
