Results 1 to 10 of 10
  1. Hi ... I am trying to add these m2ts files into Tsmuxer but once I try the first one I get a pop up box saying >> Tsmuxer not found , why ? Thanks
    windows xp pro sp3 ...
  2. Hey there ... I have already the program installed and I can use it , though once I do and look for these M2TS files which are stored on my hard drive I get the pop up saying tsMuxeR not found error . I thought this program takes m2ts files ? What I am doing is I have this blu ray movie which I have copy onto my hard drive when I went to view the folder where I saved the movie I notice many M2TS files . I thought this program can gather them altogether into one single m2ts files but once I try to add the first file I get that error ... So why doesn't it do it ? Thanks
    xp pro sp3
  3. You shouldn't open them all at once you have to open the first part using the add button or drag n drop it then press the join button and open each in order or try selecting them all at once after pressing join.
  4. Originally Posted by dylz View Post
    I wish I could do that but like I said earlier I can't even get the first to go in . I locate the files from the folder were the movie is and I select the first one , afterward I am given the option just to open which I try doing but once I do I get the pop up error
  5. Here a pic of it
    Aug 2005
    AKL, NZ
    This the gui for tsmuxer, you have the actual tsmuxer app in the same folder? Make sure you have non corrupted file too.
    Wouldn't be the first time the actual app is hit by a virus.
  7. I'll upload it since the author's official site doesn't host it anymore.
  8. and check the folder has tsmuxer.exe and tsmuxerGUI in it, you use the GUI part but it seems you don''t have the tsmuxer.exe.
  9. Originally Posted by dylz View Post
    Finally got it ... Thanks to you bud I see were I made my error ...
