Closed Thread
    Apr 2011
    Turkey
    I have Panasonic BDT300 bluray player - however, it doesn't play some mkv files thru USB. It just says "starting playpack" then nothing appearing on the screen whereas these files works on PC properly. I wrote the problem to Matroska but their suggestions (run with mkwdclean) also did not work. Do you have any idea what could be the reason?
    I would like to know if anyone has such an experience?
    unable to play;
    GeneralComplete name : D:\Filmler\The.Book.of.Eli.2010.720p.BluRay.DTS.x2 64-BIX.part01\The.Book.of.Eli.2010.720p.BluRay.DTS.x2 64-BIX_Turkish_subtitle (1).mkvFormat : MatroskaFile size : 6.33 GiBDuration : 1h 57mnOverall bit rate : 7 710 KbpsEncoded date : UTC 2011-01-09 13:17:18Writing application : mkvmerge v3.1.0 ('Happy up here') built on Jan 19 2010 12:09:24Writing library : libebml v0.7.9 + libmatroska v0.8.1VideoID : 1Format : AVCFormat/Info : Advanced Video CodecFormat profile : High@L4.1Format settings, CABAC : YesFormat settings, ReFrames : 8 framesMuxing mode : Container profile=Unknown@4.1Codec ID : V_MPEG4/ISO/AVCDuration : 1h 57mnBit rate : 5 858 KbpsNominal bit rate : 6 200 KbpsWidth : 1 280 pixelsHeight : 528 pixelsDisplay aspect ratio : 2.35Frame rate : 23.976 fpsResolution : 24 bitsColorimetry : 4:2:0Scan type : ProgressiveBits/(Pixel*Frame) : 0.362Writing library : x264 core 80 r1376M 3feaec2Encoding settings : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=1 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=0 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=6200 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00Language : EnglishAudioID : 2Format : DTSFormat/Info : Digital Theater SystemsCodec ID : A_DTSDuration : 1h 57mnBit rate mode : ConstantBit rate : 1 536 KbpsChannel(s) : 6 channelsChannel positions : Front: L C R, Surround: L R, LFESampling rate : 48.0 KHzResolution : 24 bitsTitle : DTS 5.1 @ 1.5 MbpsLanguage : EnglishTextID : 3Format : UTF-8Codec ID : S_TEXT/UTF8Codec ID/Info : UTF-8 Plain TextLanguage : Turkish
    but it is able to play:
    GeneralComplete name : G:\GCMN.2010.720p.MS.By.DarkUploader (1).mkvFormat : MatroskaFile size : 4.37 GiBDuration : 1h 43mnOverall bit rate : 6 052 KbpsThe TouristEncoded date : UTC 2011-02-26 13:47:30Writing application : mkvmerge v3.1.0 ('Happy up here') built on Jan 19 2010 12:09:24Writing library : libebml v0.7.9 + libmatroska v0.8.1VideoID : 1Format : AVCFormat/Info : Advanced Video CodecFormat profile : High@L4.1Format settings, CABAC : YesFormat settings, ReFrames : 8 framesMuxing mode : Container profile=Unknown@4.1Codec ID : V_MPEG4/ISO/AVCDuration : 1h 43mnBit rate : 4 267 KbpsWidth : 1 280 pixelsHeight : 534 pixelsDisplay aspect ratio : 2.35Frame rate : 23.976 fpsResolution : 24 bitsColorimetry : 4:2:0Scan type : ProgressiveBits/(Pixel*Frame) : 0.260Writing library : x264 core 114 r1900 60ef1f8Encoding settings : cabac=1 / ref=8 / deblock=1:-2:-2 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.20:0.20 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=2 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=4541 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=38000 / vbv_bufsize=38000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00Language : EnglishNominal bit rate : 4 541 KbpsAudioID : 2Format : DTSFormat/Info : Digital Theater SystemsCodec ID : A_DTSDuration : 1h 43mnBit rate mode : ConstantBit rate : 1 536 KbpsChannel(s) : 6 channelsChannel positions : Front: L C R, Surround: L R, LFESampling rate : 48.0 KHzResolution : 24 bitsLanguage : EnglishTextID : 3Format : UTF-8Codec ID : S_TEXT/UTF8Codec ID/Info : UTF-8 Plain TextLanguage : TurkishTitle : The.Tourist.2010.BluRay.720p.x264.DTS-MySiLUStream size : 5.19 GiB (79%)
    Just buy the movie instaed of downloading illegal warez rips. Problem solved.
