I have a free foreign film that I want to burn into a DVD but I've never authored with a separate subtitle file and would really appreciate some advice. I have the main films VIDEO_TS folder with VOB, IFO, BUP file's and two separate sub files for the subtitled; one named "Your Free Film.fragment" and the other named "VTS_01_0" and I assume I can use either? But I'm not sure how to burn the film onto a DVD with the subtitle file.
I have various authoring programs but experimenting with them all has left me scratching my head.
I'm far from a pro at authoring so please take that into consideration!
Sorry, but you would need to do considerable homwork to do this.
You need to extract the MPEG from the VOB files, and reauthor the DVD, combining with a subtitle.
No idea what "Your Free Film.fragment" is, and "VTS_01_0" could be anything. What is the file extension? -
My original files are typical VOB files for burning onto a DVD, which are in the main folder titled "Your Free Film." In that folder are 2 folders named AUDIO_TS and VIDEO_TS and within the VIDEO_TS folder are VOB, IFO and BUP files which if you burn onto a DVD give you the entire movie, just minus the Subtitles.
The movie also came with 1 additional folder named SUB and within are 2 files, one titled "VTS_0_0" (with extension .sub) and "Your Free Film.fragment" (with extension .sub) so I assume they are both subtitle files to use with, each for whatever method of authoring you choose. -
There's more than one kind of "sub" file.
Some are text based (tens of kB) others are bitmaps(a few MB).
You need to work out which kind they are
First, how big are they, in kb?
Open them both with Notepad and see if there is readable text in either. If so, copy and paste a dozen lines here. -
Hi Alan, thank you for helping me with this;
The first sub file "VTS_0_0" is 4640 KB - contains no readable data (using notepad)
The second sub "Your Free Film.fragment" is 54 KB - contains readable data, the first few lines are as follows:
# VobSub index file, v7 (do not modify this line!)
# To repair desyncronization, you can insert gaps this way:
# (it usually happens after vob id changes)
# delay: [sign]hh:mms:ms
# Where:
# [sign]: +, - (optional)
# hh: hours (0 <= hh)
# mm/ss: minutes/seconds (0 <= mm/ss <= 59)
# ms: milliseconds (0 <= ms <= 999)
# Note: You can't position a sub before the previous with a negative value.
# You can also modify timestamps or delete a few subs you don't like.
# Just make sure they stay in increasing order.
# Settings
# Original frame size
Pretty weird. You have VobSubs, but named differently. Rename Your Free Film.fragment as VTS_0_0.idx (assuming the other one is VTS_0_0.sub. Then you'll need to add those subs to the DVD, no minor task. Here's a guide:
https://forum.videohelp.com/threads/277950-How-to-add-new-subtitles-to-an-existing-DVD
Use Method 2. Ignore the stuff about SRT files. Convert those IDX/SUB files to SUP files instantly using SubtitleCreator (File->Open Subtitle, File->Save SUP). Use the SUP in the subs section of Muxman. If this movie is 16:9, you'll have to load it twice to get rid of the error message, once for Wide, the other for LB. After Muxman gets done play it as a DVD to check if the subs got in there OK. Follow the rest of the instructions about getting the subbed DVD back into the original subless DVD (assuming you want to do that, in order to keep menus and extras). Follow the instructions having to do with 'turning on' the subs (in the Update ifo files section. When all done, fix the colors using DVDSubEdit. Test the DVD for subs before burning to disc.Last edited by manono; 20th Mar 2011 at 05:53. Reason: fix typo
This process is pretty straight forward and was anxious to begin. Though it appears the .sub files I have are corrupt or unusable, Using Mediainfo confirms such. But you've all given me some excellent education on the process and wanted to thank you for taking the time to help me.
Tools for demuxing DVD Subtitle and adding Subtitle file to Blu-ray file.
By wisitch in forum SubtitleReplies: 3Last Post: 5th Jul 2011, 13:31 -
TMPGENC DVD Author Divx - Cannot import .srt subtitle files - how to do it
By wa5dxp in forum Authoring (DVD)Replies: 20Last Post: 26th Oct 2010, 10:45 -
TMPGEnc DVD Author 3 cuts off subtitle text
By headless chicken in forum Authoring (DVD)Replies: 8Last Post: 8th May 2010, 04:49 -
tmpgenc dvd author 3 cant read arab subtitle
By TheEmperor in forum Authoring (DVD)Replies: 6Last Post: 3rd Oct 2009, 08:07 -
re-author DVD adding a new subtitle language?
By u2paddy in forum Authoring (DVD)Replies: 2Last Post: 19th Apr 2008, 18:05
