Hi, I'm a newcomer to this topic.
I wonder what are the professional DVD authoring Software nowadays?
'Professional' means that the software can create DVD disc same as we bought in DVD stores.
Would u guys give me some suggestions??
Results 1 to 17 of 17
And even if you use the software that Baldrick suggests (there are equivalents and a whole lot cheaper) you will NOT create a dvd like those sold in shops.
Reason: Disks sold in shops are pressed by a duplicating plant whereas the one you will create will be burnt by a DVD-burner. Pedantic I know but that is a simple fact. -
Start here - 42 choices
http://www.videohelp.com/tools/sections/authoring-dvdRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Correct. But you would need some quite expensive hardware if you were to use that tape to create your own disk.
An authoring package such as scenarist (ulead dvd workshop could also create one) will record the 'image' on to a DLT tape which is then sent to that dvd duplicating plant. -
I use two programs. Pinnacle Studio HD for storyboard editing (with subtitling), transitions and other special effects. Then I use TMPGEnc Works 4 for making both DVD's and Blu-Ray disc's. Both are easy to learn and fun to use.
If it feels good, do it. -
Well if you check the tools (link already posted) section for dvd-authoring you will see that most, if not all, can do subtitling.
The point is that most can not be considered as 'Professional' ie used to create those disks that your original post refers to. Most are consumer level applications and some are 'prosumer' which lies somewhere between professional and consumer.
And if you want software that will create a DLT then your choice is quite limited - maybe 3 or 4 from the list of 42 (subject to whether you will be using a PC or a Mac). -
Scenarist and Ulead DVD Workshop 2 allow subtitles to be created or edited, but the consumer authoring programs I have tried expect pre-made subtitles to be provided as .sup files or in some cases, accept them in one or two other formats.
"Professional" is a reflection on the quality of work from a person.
Tools are just tools. Some meet the needs of professional work, most do not. All of my DVDs are authored with DVD Studio Pro (now part of Final Cut Studio) on Mac, or Ulead DVD Workshop 2 on Windows. Sometime I'll even use TMPGEnc Authoring Works for menu-less discs, because it's easy.
You also don't need DLT. A lot of places will let you submit on DVD-R, DVD+R, DVD+R DL or even hard drive ISO files. DLT is dated.
For example: http://newcyberian.com/dvd9rom.html#
We accept either playable DVD±R or 2 DLT Tapes (one for layer-0 and one for layer-1) as master for your DVD-9 replication order. This applies to orders that need CSS or without CSS.Last edited by lordsmurf; 16th Mar 2011 at 06:27.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video -
Well, for example, if I have a dialoge script, and a video file (mpeg, avi, mov, etc), so I want to do subtitling of this video file. Which software should I use for subtitling?
All the subtitle creation tools I know of that are not part of an authoring package are freeware, There is quite a collection of them in the VideoHelp tools section. Only some allow the use of non-western character sets, and I can't tell you which ones do. I only work with English language subtitles, and I can't remember which stand-alone subtitling tools allow alternate character sets.
If you actually look at what is sold in stores you would see there is no such thing as "Professional"!
You need to find what you want and need that does what you want done.
Professional meaning what is sold in stores means......
Disk is ratting loose in sealed case, only one they have so go to service desk and have them check the loose disk for scratches, see that the never been opened case has a broken disk holder already. Very common with Professional cases
Buy a series set and it has no PLAY ALL option so you have to play each episode 1 at a time, the menu does not move forward to next episode like many do so pressing Play starts the same one you just watched!
Set the sound either way to high or way to low for the default so people either get blasted out of the room now when disk starts, or they adjust sound up high for this disk so they can hear it and the next one they watch will blast them out.
Make sure to use disks that are plain silver on both sides and in a tiny band in the center of a one sided disk use text size small enough to write on a grain of rice the title, and maybe disk number if a set.
If this is a set of 4 disks use a case with very bad disk holders so when people open the case at least 3 disks fall out, let them worry about how to figure out which disk is what since they can't read the tiny print in the black band!
Put as menu default Scene Selection instead of PLAY Movie, make sure to only play the scene selected so if people just choose scene one that is all that plays. That way they can't just hit play for scene 1 and watch the whole movie. This is also a good trick if a person wants to start at scene 6, only play scene 6 then give them back the menu. If they want to watch the movie starting from scene 6 then let them figure out they have to Play Movie then skip chapters to the point they want to start!
Use stupid terms that mean nothing to normal people instead of Play or Select Scene
Make the menu's extra loud so if people want to watch a movie while they fall asleep the menu will be sure to wake them, let it play forever after the movie ends till people wake up and do something to shut it off.
Use weird and strange fonts in a color similar to back ground to prevent people from actually being able to read the menu choices and let them just guess which one plays the movie. Hide Play somewhere in middle also.
For Special Features put it in Main menu on disk one, when selected play loud annoying LOGO video for 1-2 minutes then put image on screen that says " Insert Disk 2 for Special Features"..
Put a 90 minute new movie onto a DVD9 in VHS quality.
When authoring or editing be sure to have several scenes with jumpy jerky flickering video to simulate fast action, probably cut every other frame or 3rd frame out to do this. So like if 30 frames per second you cut every 3rd frame and fit 45 frames of action into 30 frames! Be sure to follow the Professional newer trends, make fast action annoying to watch!
To make Professional disks and package them professionally as bought in stores do everything you can that seems stupid and annoying and use the junkiest cases you can find.
Do at least 1 of the above, preferably 3 or more, or you will not have a Profession product as found in stores!
professional dvd authoring
By adventurer9 in forum Authoring (DVD)Replies: 10Last Post: 29th Feb 2012, 18:28 -
Suggestions for DVD authoring with multiple audio streams
By farmkid in forum Authoring (DVD)Replies: 11Last Post: 19th Sep 2011, 17:23 -
What is the best professional video editing software for PC (2010)?
By exillion in forum EditingReplies: 18Last Post: 15th Jun 2010, 23:04 -
DVD authoring programs - suggestions?
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 22nd Apr 2010, 13:53 -
I'm looking for a good DVD Authoring program. Need suggestions please.
By LegendaryGamer in forum Authoring (DVD)Replies: 5Last Post: 5th Mar 2010, 20:35
