I am using handbrake to convert some old video clips (that were long ago simply transferred by scart to a DVD recorder, and now the DVD has been copied to my hard drive) . Using Handbrake they convert easily enough.
The problem is: When I play the original DVD Vob files in MS Media Player - and ensuring that the clips are displayed at 100% size (Alt + 2) - they are fine.
But after converting them in Handbrake, when playing the MP4 files in MS Media Player, the clips are displayed much larger on screen - from about 25% for the oldest video recordings to near 100% for some recent DVD clips that are Anamorphic in origin.
I want to maintain a constent size for quality. I've kept the aspect ratio, tried all the Anamorphic options, but without sucess.
Any clues anyone? I would be very grateful for any advice.
I would check your basic settings in Handbrake and tune them a tad to suit your requirements. As suggested try another media player even Windows Media Player!
TheVoiceIsAnotherPerson ~ http://www.openwiz.org/wiki/ProjectX ~ BeyonWiz DP-P1 PVR + LiDiC ~ Popcorn C200 ~ Samsung ES8000 65" LED TV ~ Windows 7 & MAC G4 -
Hey i was having the same problem the other day since i moved from AutoGK to hand break to do my conversions. I was doing the movie dogma and the picture kept coming out really squashed.
Under the picture setting when i have anamorphic set to strict which should be a direct copy of the movie and the cropping set to automatic the picture is much to squished in as just under display size it is saying 1339x428 as the resolution when the source is 720 x 576 and when you check the preview statistics in VLC player under tools it says 720x432
If i turn anamorphic to non and tick keep aspect ration with automatic cropping the resolution changes to 720 x 224 which is even smaller although it looks a little squished it still looks semi accurate but i can not understand why i cant get it to look exactly the same as the dvd. So what i ended up doing was taking the x428 from the it when it was set to strict anamorphic and gradually decreased the value to i got something i thought was an accurate representation. I don't know if im doing it the wrong way or what but it seemed to of kinda worked. -
Thanks for your replies.
Yes, I have tried VLC and other MS players - but all do the same thing...
Adjusted all the settings etc..
Can you recomend any other packages? I don't mind if they are paid for (i.e. not free or shareware)...
All I am doing is converting my old VHS TV recordings that were copied to DVD to some sort of suitable PC format, like MP4.
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 13:19 -
Is there any way to keep Handbrake from Resizing picture?
By alex.ap.pacman in forum Video ConversionReplies: 2Last Post: 19th Aug 2011, 23:42 -
Handbrake unable to scan/load source video files.
By e6bwhiz in forum Video ConversionReplies: 1Last Post: 22nd Feb 2011, 16:44 -
Video Conversion - output file size
By Leo48 in forum Newbie / General discussionsReplies: 2Last Post: 19th May 2008, 07:28 -
DVD Rip Final Size Differs
By brvignesh in forum DVD RippingReplies: 7Last Post: 10th May 2008, 10:40
