I've been editing my HD stuff, but it seems once a file has a corruption it wont load well into an editing program.
I've tried the trial version of VideoReDo, I've tried mpeg2repair and mpeg stream clip. None fix the problem.
I've no problem in losing the part which is corrupt and even if I edit out that part the clip as a whole wont be working properly (sound loops galore)
Thread: Corrupt M2T file, how to fix?
the only way i've found to get rid of the "bad spot" is to cut it out. make a clip up to the spot and then one after. usually 1/2 or 1 second is all that will be missing. if that doesn't do it and the sound is still trashed, there isn't anything else you can do.
Trying to Fix a Huge Corrupt .avi File!
By LPrime in forum Video ConversionReplies: 36Last Post: 14th Oct 2012, 16:45 -
Comcast/Moto 6412 - How to fix/avoid corrupt .TS captures?
By Tiernan in forum DVB / HDTVReplies: 12Last Post: 30th Apr 2011, 09:56 -
Corrupt MP4 (H.264) fix?
By Xplaya in forum Newbie / General discussionsReplies: 3Last Post: 6th Jul 2010, 17:04 -
I need your guys help, repair/fix corrupt video
By jace89 in forum Newbie / General discussionsReplies: 2Last Post: 14th Aug 2008, 18:52 -
Can I fix this? (was: Tivo transfer/corrupt file)
By trimicada in forum Newbie / General discussionsReplies: 3Last Post: 23rd Oct 2007, 19:05
