Hi guys.......i installed servis pack 1 for windows 7 yesterday.....i've just tried to use software to encode a movie, and its now not working. It starts to open, then page just closes again......Anyone else had this problem??? Any solutions, or ideas??
H4MST3R
Have you tried reinstalling?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
i haven't...but ive just read on the microsoft forum that the new service pack does have known issues that can cause some software from not working....im just uninstalling the service pack to see if that does the trick.......n
it is likely that SP1 is considered a major change to the software and as such SVCD2DVD/VOB2MPG will need reinstalling/registering.
Ok guys....just to let you know...after uninstalling the service pack 1 and restarting...svcd2dvd now works fine again!!!
nice one microsoft (again!) -
I run SVCD2DVD on two desktop PCs, both running Windows 7 and have been using it for several years. There is definitely a problem once Service Pack 1 has been installed, however it is easy to remedy. Don't be put off by the length of the instructions - I just wanted to break it down to be as simple to follow as possible. To fix any problems with SVCD2DVD take the following steps:
- Uninstall SVCD2DVD
- Reboot computer.
- Install latest version of SVCD2DVD - DO NOT install to the default location of "Program Files". Instead create a new folder named "SVCD2DVD v2.5" (or another unique name that you have not installed the program to before, without the quote marks) on the local drive. For example: C://SVCD2DVD v2.5/
- Don't start the program up just yet.
- Go to the Start Menu and locate the shortcut for SVCD2DVD.
- Right click on the shortcut and choose PROPERTIES.
- Click on the COMPATIBILITY tab.
- Place a tick in the "Run this program as an administrator" box.
- Check that it is also set to run in the compatibility mode of Windows XP (Service Pack 2).
- Click on OK.
- Go back to the shortcut in the Start Menu.
- Right Click on the shortcut and select "Pin To Start Menu" (This step is optional, but it means the shortcut for SVCD2DVD will always be in the start menu, and will always run as administrator.)
Need help-Been using ripbot for sometime now....it has stopped working.
By clefus in forum Blu-ray RippingReplies: 3Last Post: 13th Jan 2011, 12:42 -
SVCD2DVD Stopped Working
By magic90 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 28th Sep 2010, 08:07 -
Why have my TV speakers stopped working?
By jimbo7777 in forum AudioReplies: 6Last Post: 17th Apr 2010, 19:19 -
svcd2dvd ffmpeg has stopped working adding dvr-ms
By Pooch917 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 1st Mar 2010, 10:00 -
WMP stopped working?
By glowworm12 in forum ComputerReplies: 5Last Post: 22nd Feb 2008, 09:44
