    Feb 2011
    London
    I have a scientific documentary in mp4. It has a sub printed in , I would like to extract it. I have used Yamb and subrip (suggested in this forum) the last one use an interested function called sub to text via OCR .. but doesn't work. It is very important for me because I can easy study it with a sub written
    I will be veri gratefull if some one can help me
    What happens with subrip? No mp4 support? Maybe try convert to avi(winff, xmedia recode) or use avisynth and then open in subrip.
    Feb 2011
    London
    Thanks ...with SubRip i can use only VOB (I have used nero to obtain a VOB file ). I will try the programs sugested and I will let you know
    Feb 2011
    London
    How you can see from the image with SubRip I can use only VOB files.
  5. In Yamb click on "editing > click to extract streams" and open your .mp4 file. If you don't see a subtitle stream there that means it's hardcoded and there is no way to extract it. If you do see a subtitle stream, click on it and "extract to raw format". You can then open the .srt in Notepad to read it or edit it.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    In subrip under File->Open Hard subbed video files. But it might only work with avi files or avs avisynth scripts.
  7. Cool, subrip can OCR hard subs? I did not know that! /Ed McMahon voice
