I have a DVD that I placed as the default audio a Japanese language track the default English subtitle comes on as well when you start the DVD. Now I have added as a secondary audio the English dubbed track to the movie.
So my question is it possible when a user selects (as the movie is playing) the English audio track to turn off the subtitle track automatically? Or would I have to manually turn them off myself when selecting that track?
It seems like it would be possible in PGCedit but I'm not sure how?
You'll need to edit the nav commands for the title by adding two sets which determine the correct playback
A: Japanese audio / english subtitle (default) (goto + setstn)
B: English audio / no subtitle (secondary) (goto + setstn)
This also needs to be reflected in the leading menu
Problem is we dont know the structure of dvd's layout.
For more help the following should be done.
1: Pgcedit > Info > dvd commands + menu bottons/bov commands ... save both and post. -
OK, so I thought it might be a bit simpler like when I added the "setstn" to turn the subtitles on by default.
The main title is VTST 1 (1:23:43), it shows the audio stream 0, and subtitle 0 on by default. There are 4 audio tracks total;
Stream 1=Japanese 5.1
Stream 2=Japanese 2.0
Stream 3= Commentary
Stream 4= English (this is the one when selected I want to automatically set the subtitles to "off")
Hopefully I have uploaded the files (in .txt format) correctly;Last edited by kpic; 19th Feb 2011 at 13:36.
You will not be able to do what you want.
Selection of audio and subtitles is done by Pre Commands in a Title.
You can than change them on the fly (while DVD is playing) using remount, because DVD is not going to go to any of those commands any more.
If you want to make it selectable, you will have to add a menu button which will select your English audio, than add a few Title pre commands which will deselect subtitles if English language is chosen. -
Thanks tinker, when you explain it like that it makes sense - not sure why I thought it could be possible to set a flag for what I want to do while "on the fly".
Automatically Delete Select Frames
By mikesaunders in forum EditingReplies: 9Last Post: 6th Apr 2012, 00:16 -
Button command(s) to select audio and subtitles simultaneously
By dexter30 in forum Authoring (DVD)Replies: 1Last Post: 26th Mar 2012, 15:42 -
Automatically reducing the gap between subtitles
By Niggylefrançais in forum SubtitleReplies: 2Last Post: 10th Jul 2011, 09:48 -
Select subtitles automatically in a DVD
By dexter30 in forum Newbie / General discussionsReplies: 0Last Post: 7th Nov 2010, 09:38 -
How to have new DVD subtitles activate automatically?
By semmel in forum SubtitleReplies: 2Last Post: 28th Feb 2008, 11:23
