hi, I am desperately trying to get the DV tapes copied on to Final Cut Pro. I have just tried connecting the camcorder to the pansonic HDD/dvd recorder, and connecting my mac to the USB port and then the fire Wire port. Neither have worked (I was told to do this by apple!!!). I have now ran out of ideas. I've tried looking for all sorts of adapters to connect the camcorder straight to my computer. As you can tell I'm not majorly technical, so any help you can give i would greatly appreciate!!!![]()
laurie
the panasonic most likely doesn't do analog to digital passthrough. your best bet is to record it and make a dvd with the panasonic. then import the video off the dvd to fcp. otherwise you need to buy another video camera or capture device that does analog to digital passthrough over firewire.
no not mini DV
otherwise i could have done that. It's the bigger tapes, and I cant connect it straight to my computer which is annoying
Is it SD or HD? IF they're SD AND you have a way to get back to the studio where they were recorded (so they may be played back to analog - yellow/red/white cables) AND you have access to a camcorder like the aforementioned Canon ZR series, that camcorder permits analog input so you may re-record the analog footage to mini-DV (of course, at a lower bitrate—5GB/hour??) and then bring those tapes to your Mac.
Just trying to find another way to skin this cat...
(aedipuss's suggestion is akin to mine but going to DVD transcodes to MPEG2 first and then you have to bring it back to AIC or ProRes. Whether my suggestion of going back to analog and then into DV-Stream results in any better quality I can't say for sure but I believe so.)
Canon HV20 to Final Cut Pro 7
By edurbrow in forum Newbie / General discussionsReplies: 7Last Post: 22nd Jan 2012, 09:01 -
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 05:04 -
Canon Vixia HF S20 and Final Cut Pro 6
By amriteshvara in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 11th Sep 2011, 11:43 -
from vob2mpg into MAC Final Cut Pro - no audio
By finedesign in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 27th Jan 2010, 03:43 -
How to convert srt/sub/ssa to SON/SCR for "Final Cut Pro" on Mac
By mriddler in forum SubtitleReplies: 18Last Post: 3rd Nov 2009, 07:08
