I have 2 AVI files (2 halves of a film) and the second one is a different size to the first so VDub64 will not allow me to join them. I used Vdub64's resize filter in the video menu to resize the second AVI clip and it now has gone from 700 MB to 80.4 GB. Surely that's not the right way to do it! Is there a way of resizing the AVI file, keep it at the same file size so I can join the two together using the direct stream copy in the video menu to keep the overall file size down?
OK, so resize the second clip so the two match and use compression. I'm using the lagarith lossless codec to do so. Is that a good one? I think I'll have to run the first one though a lagalith comression run too so the two clips are compressed using the same codec. Then rejoin. It'll be interesting to see what the final file size is
Yes it is. 19 GB. So how do I get it down to say 700 MB like the original file?
Converting to avi keeping same screen size
By Dungogvolts in forum Video ConversionReplies: 18Last Post: 15th Apr 2012, 20:57 -
Is there a max file size when Joining avi files.
By admjim in forum ffmpegX general discussionReplies: 2Last Post: 14th Feb 2010, 03:41 -
Resizing video file size using handbreak question.
By demonhunter in forum Video ConversionReplies: 2Last Post: 19th May 2009, 06:23 -
Best way to go from MJPEG (1280x720) to small file size keeping quality
By Mysteriouskk in forum Video ConversionReplies: 7Last Post: 27th Nov 2007, 16:21 -
I'm new to Joining multiple avi files into one big file....
By Lahori82 in forum EditingReplies: 4Last Post: 29th Aug 2007, 13:05
