VideoHelp.com Forum
Results 1 to 12 of 12
  1. I'm a MEGA Super Moderator Baldrick's Avatar
    With Freemake Video Converter can you easily convert everything to anything with burned in subtitles. It supports sources like MKV, MP4, DVD with embedded subtitles. Convert to AVI, MKV, MP4(profiles for Iphone, Ipad, Android etc), DVD, Blu-ray.
    Tools
    Guide
    Load your source video. If your video already has subtitles just click on subtitles to choose the subs. Or else click subtitle and load from an external source(srt/ssa/ass).
    Click to AVI/MKV/Apple/Andoir/DVD/Blu-ray to select profile and encoding settings.
    I'm converting to my Nexus One Android mobile.
    Start encoding and wait....
    Test with MPCHC
    Done.
    Search keywords: Burned in, permanent, hard coded, hardcoded subtitles.
    Great guide and a excelent program.
    Is there a way to change the subtitle size when converting to DVD?
    very best this is Great program
  4. Can anyone find how to change where this program's temp folder is? It defaults to c:\Freemake_do_not_remove_this_folder and I'm working with Blu-Ray, so it fills it up and fails.
  5. Is there a way to use more then one Audio and Subtitles? In the Pulldown-Menu of every File i want to convert, i have more Audiostreams ans Subtitles but i can just choose one?
  6. Should this support IDX/SUB?
    I installed Freemake Video Converter with much expectations.
    The installation was error-free. However, running the program gave error "The program has.. report to Microsoft".
    I have Windows XP-SP3.
    Any suggestion, please?
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Have you installed .net framework 4? http://www.microsoft.com/download/en....aspx?id=17851 . It is required.
    Yes, it is installed and I have updated after your reply as above. Same problem occurs!
  10. Hi ConverterCrazy,
    For what is worth try Downloading The Standalone .NET Framework 4 from the link below ... read carefully, I think I saw something about the XP machine might need something else ... but the link for what you might need is in there.
    This Link is the Page One ... after you download look at Page Two also ... has some more info ...
    http://www.microsoft.com/download/en....aspx?id=17718
    Post back your results for the next person!
    G!
    Hi gonkw,
    Thanks for the replying.
    I followed your suggestion and was able to "repair install" The Standalone .NET Framework 4 unlike earlier when the The .NET Framework 4 installer exited without performing repair/install.
    However, the Windows XP again gave same Error message and sent report to Microsoft and FreeMAKE Video Converter too sent Error Log to the authors of the program.
    Sorry, I could not follow what page 2 says. It is so full of "computerese"
    Wish there were simpler way in the form of do-this-and-dont-that.
    Thank you once again for your time and suggestion.
    I agree Freemake is a good and convenient software but it cannot retain DTS audio encoding.
  1. Batch convert DVD folders easily?
    By tomkat2010 in forum Video Conversion
    Last Post: 6th Mar 2012, 18:10
  2. Replies: 31
    Last Post: 8th Jan 2012, 07:04
  3. Convert AVI to iDVD compatible file with burned-in subtitles?
    By tictacjak in forum Video Conversion
    Last Post: 7th Sep 2011, 12:28
  4. How to easily convert .ts files to Mpeg2 or DVD
    By renzo2000 in forum User guides
    Last Post: 25th Aug 2010, 16:03
  5. Replies: 3
    Last Post: 22nd Apr 2009, 03:34
