    I downloaded a video that was encoded with the opposite aspect ratio than it should have been so everything is squished. It's a resolution of 352 wide by 480 high. Is there an easy way to resize it to the opposite dimensions or any other proper size?
    You can probably specify the display aspect ratio at the container level. Mpeg4Modifier for Divx/Xvid AVI, Restream for MPG (must demux to M2V, then remux), MMG for MKV, Yamb for MP4.
  3. Always Watching guns1inger's Avatar
    The resolution is half-D1. If the video is mpeg-2 you could author it into a DVD Video and it will playback correctly. If it is an avi file then it has been (badly) encoded from a half-D1 source. You could try the above suggestion of mpeg4modifier, and if that doesn't work, resize it to 352 x 240 and re-encode
    Read my blog here.
    Jagabo, I tried Mpeg4Modifier and it worked great! Thanks!
