    Hi All
    Ive been using Ripbot for sometime now to convert files to mkv, it has been working well with no issues
    Today when i try to do a conversion i receive the below error
    Can't open "G:\temp\RipBot264temp\job1\getinfo.avs"
    If i browse the folder the file is there
    I have tried multiple source files, all give the same error, nothing on my pc has changed, and this was working fine only 2 days back..
    Anyone have any ideas why this is happening?
    Below is an ouput from my log
    eac3to v3.24
    command line: "C:\RipBot264v1.16.4\Tools\eac3to\eac3to.exe" "C:\abc\abc\" 1) 2: "G:\temp\RipBot264temp\job1\video.mkv" -seekToIFrames 3: "G:\temp\RipBot264temp\job1\audio_English.dtsma.w6 4" -down16 1: "G:\temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="G:\temp\RipBot264temp\job1\demuxlog.txt"
    M2TS, 1 video track, 2 audio tracks, 2 subtitle tracks, 1:56:22, 24p /1.001
    1: Chapters, 14 chapters
    2: h264/AVC, 1080p24 /1.001 (16:9)
    3: DTS Master Audio, English, 5.1 channels, 24 bits, 48kHz, 83ms
    (core: DTS, 5.1 channels, 24 bits, 1509kbps, 48kHz)
    4: TrueHD/AC3, English, 5.1 channels, 48kHz, dialnorm: -27dB, 83ms
    (embedded: AC3, 5.1 channels, 640kbps, 48kHz, dialnorm: -27dB)
    5: Subtitle (PGS), English
    6: Subtitle (PGS), English
    Creating file "G:\temp\RipBot264temp\job1\chapters.txt"...
    [v02] Extracting video track number 2...
    [a03] Extracting audio track number 3...
    [a03] Decoding with ArcSoft DTS Decoder...
    [a03] Applying RAW/PCM delay...
    [a03] Reducing depth from 24 to 16 bits...
    [a03] Writing W64...
    [v02] Muxing video to Matroska...
    [a03] Creating file "G:\temp\RipBot264temp\job1\audio_English.dtsma.w6 4"...
    [a03] The original audio track has a constant bit depth of 24 bits.
    [a03] The processed audio track has a constant bit depth of 16 bits.
    Added fps value (24 /1.001) to MKV header.
    Video track 2 contains 167399 frames.
    eac3to processing took 18 minutes, 28 seconds.
    Done.
    Hi All
    If anyone else has the same error, i fixed it by unistalling avisynth and reinstalling
    Kamran
  3. Originally Posted by kamranj View Post
    Hi All
    Kamran
    You probably will never see this, but I thank you very much for posting that last bit
    Reinstalling Avisynth_258.exe works. Thanks Kamranj.
