Hi, bit of a problem. I recently bought this Dvd player, it reads normal DVD's fine, and it plays media through the USB fine too. The problem is my burnt DVD-R's. It doesn't recognise the disc.
I done a test with the same film on USB and on the disc, it worked perfectly through the USB, the disc works in my laptop, PS3, and my other Divx enabled DVD player. I can't remember the make of the other DVD player, but it was cheaper that this Toshiba (which is cheap anyway) and it handles them fine.
I don't see how it could be a disc drive fault as it reads normal DVDs, and it's region free.
What else could be the culprit? I'm usually okay with this type of thing, and have spent quite a while researching online but have come up with nothing and it's getting pretty frustrating.
I'd appreciate any help you can offer, thank you.
Have you tried a DVD+R disc?
Some older DVD players were picky about DVD+R or -R. -
Yes, try to reburn the disc using a +R bitset (in burning software book type setting) to "DVD ROM" and see if that works...
Thanks for replying.
The way I burn my discs is in Vista, I just highlight what I want to burn and then click the burn button.
It has always worked.
I'll go get some DVD+r now and try with those, but I don't think it will make a difference. This DVD player is newer than the other one, and it's a DIVX enabled player, and was advertised to play all different types of discs. I got it for the same reason I got the other one, so I wouldn't have to convert anything to be able to play them, just a simple burn.
Please take a look here.
And at the specifications on the same page, this player should be able to handle a burnt DVD-r.
Right, I'm going out to buy some DVD+r now to see if it makes a difference.
Thanks again. -
Oh, so it won't play them from a DVD-R? That's a shame. I just have to stick with the USB then.
Thanks all for you help.
Problem with recently burnt DVDs not reading suddenly in any player
By Xmetalfanx in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Jul 2011, 22:27 -
Any tools for copying / reading bad quality discs?
By Locut0s in forum DVD RippingReplies: 2Last Post: 12th Nov 2010, 08:06 -
Toshiba Sat. A200-AH6 laptop DVD drive cannot read DVD DL discs
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 9th Dec 2009, 02:27 -
DVDFab HD not reading discs.....
By E_Merlin in forum DVD RippingReplies: 19Last Post: 19th Jan 2008, 21:40 -
problem reading some discs
By nick6878 in forum DVD RippingReplies: 5Last Post: 3rd Jan 2008, 10:25
