Don't worry, I read the threads and fixed the whole invert audio/QT fix that so many had issues (I think) with but now I'm getting a massive error and don't know where it's coming from or why. Any help would be appreciated.
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Fri Feb 4 00:12:30 EST 2011
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x5597b8]negative ctts, ignoring
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/nat/Desktop/SKINS_QT1.mov':
Duration: 00:00:45.1, start: 0.000000, bitrate: 4402 kb/s
Stream #0.0(eng), 23.98 fps(r): Video: h264, yuv420p, 960x540
Stream #0.1(eng): Audio: adpcm_ima_qt, 48000 Hz, stereo
Output #0, flv, to '/Users/nat/Desktop/SKINS_QT1.mov.ff.flv':
Stream #0.0, 23.98 fps(c): Video: flv, yuv420p, 640x352, q=2-15, pass 1, 1100 kb/s
Stream #0.1: Audio: mp3, 44100 Hz, stereo, 128 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
[h264 @ 0x54340c]abs_diff_pic_num overflow
[h264 @ 0x54340c]decode_slice_header error
[h264 @ 0x54340c]concealing 2040 DC, 2040 AC, 2040 MV errors
h264.c:4144: failed assertion `h->long_ref_count + h->short_ref_count <= h->sps.ref_frame_count'
I have no idea what the errors mean, or if it is due to the version of ffmpeg that ffmpegX uses.
Will ffmpegX convert the clip to any other format? Perhaps using a mencoder preset? -
Well based on another thread suggest and Case, I first converted to IPOD h.264 640W and then to FLV and that seems to work pretty good. Still don't know what's going on with MOV to FLV?
The difference between default FLV encoding and default iPod encoding is a setting in the Options tab, which can be active or inactive and is in fact optional.
FLV encoding have "Decode with QT" de-selected by default, and iPod encodings have it selected by default. What this does, is that ffmpegX "asks" QuickTime to read the source video behind the scenes, and deliver the YUV frames to ffmpegX. So, for H.264 video that QuickTime can read, but this version of ffmpeg can not read without errors, this makes a huge difference.
You may try again MOV to FLV with this option selected, just to see if it works okay now. -
Checking the Decode with QT seems to work on most of my MOV files but not all. I'm not sure what differs in some of the files that won't allow for a direct MOV to FLV conversion. I'm comparing my MOV files to see if I can detect any differences but as of now I'm happy that I can get a FLV file by some means. Thanks.
mov to flv framerate issue with ffmpegx
By Sebbeto in forum ffmpegX general discussionReplies: 5Last Post: 23rd Mar 2010, 01:20 -
Issue converting a .mov to a .flv
By bopdro in forum ffmpegX general discussionReplies: 1Last Post: 5th Mar 2009, 13:15 -
.mov conversion to .flv - issue with caption
By jp_drums_4evr in forum Video ConversionReplies: 0Last Post: 29th Jun 2008, 15:40 -
.mov to .flv - Sync issue and shortened video.
By dillingham in forum ffmpegX general discussionReplies: 1Last Post: 4th Jun 2008, 17:15 -
Divx to FLV to MOV to FLV again, just for the sake of some effects?!
By ayyash in forum Newbie / General discussionsReplies: 2Last Post: 5th May 2008, 21:19
