Results 1 to 14 of 14
    I have many flv videos (AVC/AAC) which I want to mux into a mkv video. Is there a way to mux all the videos at once. Because doing it one by one is taking to long. Thanks in advance
    ffmpeg
    1) download ffmpeg, place copy of ffmpeg.exe in same folder as flv files
    2) write the following in notepad, save it, rename extension .txt to .bat
    for %%a in ("*.flv") do ffmpeg -i %%a -vcodec copy -acodec copy %%~na.mkv
    3) double click .bat file
  3. Member bat999's Avatar
    kudos to poisondeathray.
    Neat solution.
    The ffmpeg website is a bit confusing. This is where the Windows versions are, ffmpeg-latest :- http://tripp.arrozcru.org/
    Thanx it does exactly what i wanted
    That site is quite out of date - latest version there is from April 2009.
    More recent builds can be found at http://ffmpeg.arrozcru.org/autobuilds/, but that site too is no longer being updated - last 'daily' build is from 17th Jan 2011.
  6. Member bat999's Avatar
    No it isn't, this is the version from ffmpeg-latest:-
    FFmpeg version SVN-r26268, Copyright (c) 2000-2011 the FFmpeg developers
      built on Jan  8 2011 18:14:39 with gcc 4.4.1
    Odd - I don't see that version on http://tripp.arrozcru.org/ - latest I see is r18639 from 21 April 2009.
    (In any case, it's still older than the last one created on http://ffmpeg.arrozcru.org/autobuilds/, which is r26400 from 17 Jan.)
  8. Member AlanHK's Avatar
    I suppose there is some reason that this isn't on Sourceforge?
  9. vanished El Heggunte's Avatar
    ffmpeg has moved from SVN to GIT.
    The latest SVN build of ffmpeg @ SourceForge is 26112.
    The autobuilds @ arrozcru used SVN.
    Let's hope someone will write an idiot-proof guide to compiling ffmpeg on Windows.
    Ok but how do you mux multiple .flv's into one .mkv in the ffmpeg command line?
  11. Try on Drag Drop Convert, it can mux multiple file to MKV.
  12. Originally Posted by poisondeathray View Post
    ffmpeg
    That is wonderfully elegant, but it does not word with files that have non-ASCII characters in the name. Can this solution be made Unicode-friendly?
  13. Member AlanHK's Avatar
    Lots of command line programs can't cope with non-DOS names.
    You need to reference the short filename, using the ~s modifier
    I think :
    for %%I in ("*.flv") do ffmpeg -i %%~sI -vcodec copy -acodec copy %%~nsI.mkv
    would work. (Haven't tested it.)
  14. Thanks, AlanHK, it works!
