  1. I'm in UK so if you could convert prices that would be great!
    Less than 60 please
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    For what purpose?
    If intended to be camera mounted, check the Rode
    http://www.youtube.com/watch?v=J_89pBQ0wp0&NR=1
    http://www.youtube.com/watch?v=oA3dd1L9fPY
    Better to put the shotgun on a hand held boom and keep it within 2m to talent.
Size:  43.9 KB Name:  boom-02.jpg
    http://www.kiva.org/about
  3. I'm looking at ebay at the moment and can get a sony shotgun mic for about 20, shipped from US, which is excellent. But i have no idea how to use it. Would i plug straight into camera, or convert it to stereo first then plug it in, or if i want to listen to it what would i do? i only have 1 audio input.
  4. Member edDV's Avatar
    Mar 2004
    First it won't be as good as the Rode.
    Sony and Canon make special shotgun mics that connect through their separate proprietary hot shoe connectors. Some of these even change the directional audio pattern as you zoom the lens. You need to match the mic to the camcorder model. Other mics connect through the HiZ mini plug. Pro Mics are usually LowZ (with XLR connectors) and need a transformer adapter or converting mixer to work with consumer camcorders.
    I suggest you get the Rode. I have the Sony and Canon hot shoe mics and neither match the Rode.
  5. but i don't want it so it's on the camera i want to freely move it about.
  6. Member edDV's Avatar
    Mar 2004
    High impedance consumer mics can't use long cables. That gets you either into low impedance pro mics (balanced XLR cables), or a wireless solution.
