I'm going to be helping to edit some film this weekend for a film I was involved in making. The last film we made; people said that it needed to be deinterlaced as it was very jagged. You can see the film here: http://www.communityfilmproject.org/2010/10/alley-pop/
This time around I want to make sure the film is deinterlaced properly and that it also runs at 24 fps so it looks like a movie. Any tips to keep in mind for conquering these issues?
Yep, shoot using film cameras and not video cameras. If your current project was also shot using interlaced 29.97fps video cameras then, although it can be deinterlaced, it'll never look like film and can't (properly) be converted to film speed.
Also, your whites are badly blown out. -
You can use a good deinterlacer to go from 30i to 30p. VirtualDub or AviSynth's Yadif deinterlace is pretty good. AviSynth's QTGMC() is better but very slow. But to get to 24p you'll have to decimate. That will leave you with several little jerks every second. And then YouTube will duplicate frames to get it back to 30p, making it even jerkier. The "film look" has less to do with frame rate than it does with lighting and framing. If you really want 24p you need a camera that shoots 24p.
Ah! I've seen so many 30 fps youtube videos with a duplicate frame every 5 frames I assumed YouTube was converting 24 fps to 30 fps.
Help deinterlacing/IVTC'ing VHS material converted years ago from film
By Mini-Me in forum Video ConversionReplies: 25Last Post: 4th May 2015, 13:46 -
Help with making VobSub 2.23/2.39 run under WinXP
By hibbs in forum Newbie / General discussionsReplies: 4Last Post: 9th Dec 2010, 16:10 -
Getting film look on BFF PAL DV video without deinterlacing?
By arminio in forum RestorationReplies: 0Last Post: 17th Sep 2010, 03:21 -
FPS NTSC & PAL Film/Digital
By flamingo in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2007, 13:21 -
2 DVDs of same film run different lengths but no missing scenes
By headless chicken in forum MacReplies: 2Last Post: 27th Sep 2007, 18:20
