Hi,
I am trying to convert video files to the webm format. I am using
FFmpeg and have installed the libvpx library. I can confirm this when
I run the following:
$ ./ffmpeg -formats 2> /dev/null | grep WebM
E webm WebM file format
$ ./ffmpeg -codecs 2> /dev/null | grep libvpx
DEV libvpx libvpx VP8
Which means I should be able to convert to webm? However when I run
"ffmpeg -i [input.mp4] [output.webm]", I get the following error:
"Encoder (codec id 146) not found for output stream #0.0"
Has anyone got any ideas?
Many Thanks.
Hi
When I run the same grep commands I get similar results:-
And it converts OK with your command:-Code:x@ubuntu:~$ ffmpeg -formats 2> /dev/null | grep WebM D matroska,webm Matroska/WebM file format E webm WebM file format x@ubuntu:~$ ffmpeg -codecs 2> /dev/null | grep libvpx DEV libvpx libvpx VP8
And the result is the same if I use command:-Code:ffmpeg -i input.mp4 output.webm
So maybe there is something wrong with your libvpx compilation/installation.Code:ffmpeg -i input.mp4 -vcodec libvpx -acodec libvorbis output.webm
Try testing libvpx and libvorbis individually.
Like this:-
and this:Code:ffmpeg -i input.mp4 -vcodec libvpx -an output.mkv
Code:ffmpeg -i input.mp4 -acodec libvorbis -vn output.mka
Code:Complete name : output.webm Format : WebM File size : 7.20 MiB Duration : 3mn 0s Overall bit rate : 335 Kbps Writing application : Lavf52.92.0 Writing library : Lavf52.92.0 Video ID : 1 Format : VP8 Codec ID : V_VP8 Duration : 3mn 0s Bit rate : 249 Kbps Width : 480 pixels Height : 272 pixels Display aspect ratio : 16:9 Frame rate : 25.025 fps Compression mode : Lossy Bits/(Pixel*Frame) : 0.076 Stream size : 5.35 MiB (74%) Language : English / English Audio ID : 2 Format : Vorbis Format settings, Floor : 1 Codec ID : A_VORBIS Duration : 3mn 0s Bit rate : 64.0 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Bit depth : 16 bits Compression mode : Lossy Stream size : 1.37 MiB (19%) Writing library : aoTuV b5d (UTC 2009-03-01) Language : English / English
I'm trying to open .WebM in VirtualDub
By alinhoalisson in forum Video ConversionReplies: 25Last Post: 22nd Sep 2014, 06:20 -
all youtube video now being trancoded to WebM
By aedipuss in forum Latest Video NewsReplies: 12Last Post: 31st Oct 2012, 15:26 -
Webm Codec Advice Needed
By jg84 in forum Software PlayingReplies: 9Last Post: 20th Apr 2012, 20:10 -
WebM and OGG Theora in FFMPEGX?
By simpleknight in forum ffmpegX general discussionReplies: 0Last Post: 25th Jan 2012, 14:36 -
some ffmpeg help with webm/vp8
By loldmanjenkins in forum DVD RippingReplies: 8Last Post: 3rd Nov 2010, 15:04
