Here's my issue:
I'm trying to convert a video file (.mkv) with DTS audio to another .mkv file with AC3 audio. Of course, I can use a software such as MKV video converter, but it will only process the video file as a whole; which will take around 2 days for a 15 Go video file...
Here's how I am progressing:
1 - I used tsMuxeR to extract the DTS audio file from the video file...the extracted file is a .ts extension.
2 - Then, I used xVid4PSP 5.0 to convert that audio file from the DTS format to the AC3 format...it created an audio file with a .ac3 extension.
3 - Here's where I get stuck: How can I add that .ac3 audio file back into the original .mkv to kinda "overwrite" the old audio format (DTS)?
Audio is a lot faster to process conversion-wise rather than converting the whole video including all the tracks...
Does anyone have the required knowledge to help me out?
Thanks!![]()
Results 1 to 12 of 12
mkvtoolnix
push add, open old .mkv, push add, add new ac3 track, uncheckmark old dts track , push start muxing -
No you didn't try it already...
It can only export mkv, not other formats
mkvtoolnix = mkvmerge NOT tsmuxer
another method
http://www.videohelp.com/tools/PopCorn_MKV_AudioConverter -
I think you're confused with the programs
there is no .ts format option in mkvtoolnix
if you already did your conversion to ac3 (i.e you finished your steps 1 & 2 in your original post), follow the steps in post#2
if you want to start all over again, try popcornhour mkv audio converter in the link above
O use EZmkvDTStoAC3v1.1 to do that. Simple and fast.
Awww Geez! Yeah I was a bit confused; I thought you were talking about tsMuxeR...I downloaded MKVtoolnix and am currently converting it; will get the results in a couple minutes...
Thanks everyone! All of your options will be evaluated for sure. I didn't expect to have as much support as that.
Thanks again to everyone on this post -
@mdelisle1
Surprisingly you can use Avimuxgui folowing the EXACT steps
poisondeathray provided for you.......
Have a nice day[and happy muxing],
M -
What I do is de-mux the mkv with MKVcleaver into it's streams. I insert the DTS stream into DAudioK and convert the DTS into AC3.
Finally, I reinsert the streams I want back into mkv format with MMG (from MKVToolNix). Usually I also re-insert subtitles in the form of SRTs into it as well. To get the SRTs I use Suprip.
Tony
How to convert a AAC audio file in a mkv file to AC3?
By wolvie77 in forum AudioReplies: 4Last Post: 13th Mar 2012, 21:59 -
My TV doesn't run either .DTS and .AC3 file from .MKV movie
By galodoido12 in forum AudioReplies: 2Last Post: 3rd Feb 2012, 23:29 -
mkv-dts to mkv-ac3 5.1
By nicknack74 in forum AudioReplies: 13Last Post: 24th Jul 2011, 12:59 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 21:24 -
Converted mkv file can't keep DTS audio
By thegrube in forum Video ConversionReplies: 4Last Post: 11th May 2009, 14:49
