I am just getting started in converting my old vcr tape home movies to dvd's. Also have numerous 8mm video cassettes to transfer to dvd's. Need help on selecting best and quickest equipment for this process? Any help would be appreciated. Thanks.
This is a regular topic on here, take a look here you should find some useful information https://forum.videohelp.com/threads/330494-VHS-to-PC-capture
I've just won the lottery, what would i want with a bitch like you.
csi crime scene -
Simplest is to get a set top dvd recorder. Just plug in your vcr or video camera, press play on the tape you want to record, put a blank dvd in the dvd recorder and press record on the dvd recorder. Plain and simple.
Of course there are a lot of other options you can look into. How complex you want to get depends on your end result you want to achieve and what quality your tapes are in.
Check the link mickish provided and browse the website on vhs to dvd with the built in search feature.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
PC capture produces the best quality - but is more difficult.
The early transfers that I did with a Panasonic DMR-E20 (and the little black box from ebay) have flaws that I don't care for.
Three (better) VCRs later, and a Hauppauge PVR-250: I'm more satisfied, but it IS VHS that I normally transfer from. 8mm should yield better results, so I'd stick with a better setup - instead of easiest.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
"Best" and "quickest" are the antithesis of each other when it comes to VHS to DVD transfers. So are "best" and "cheapest". Reasonable price, reasonable quality, fast, and easy, is a DVD recorder with line TBC recording 1 hour on a single layer disc. Best will involve purchasing US$1000 in equipment (much of it used because it's not made any more) and spending a lot of time learning how to use it and the software. There are many threads here that discuss that. I'm pretty sure it's not what you want so I won't bother searching and linking to them.
Note, the DVD recorder route won't work with commercial tapes that include Macrovision copy protection.Last edited by jagabo; 16th Jan 2011 at 19:27.
VHS to DVD Recording - 4:3 VHS Becomes Widescreen on DVD
By Ocracoke Pelican in forum Newbie / General discussionsReplies: 1Last Post: 31st Dec 2011, 13:04 -
VHS To DVD Recording errors
By DuBsTaR in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2010, 12:31 -
VHS to DVD with AVI/WMV recording?
By Jorabi in forum DVD & Blu-ray RecordersReplies: 14Last Post: 14th Nov 2008, 14:48 -
DVD-VHS Recorder Proplem with Recording
By mactek in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th Nov 2008, 15:02 -
recording from VHS to DVD - picture flickering.
By glen_s in forum DVD & Blu-ray RecordersReplies: 3Last Post: 15th Jun 2008, 10:23
