Maybe my post in the Newbies folder is best placed here? Here goes:
https://forum.videohelp.com/threads/330309-Help-w-playback-issues-on-blu-ray-player-of-dvr-recording
I wasn't entirely sure where this issue should go as there are a few different components and programs involved in the overall matter. If it needs to be moved, please do so (and advanced apologies). So here goes...
I am using a MacBook Pro, TiVo Premiere, MPEG Streamclip, iTiVo, VLC Player, Sherwood BDP-5004 blu-ray & dvd player, and sometimes Toast Titanium, first off. I have dvr'd a HD recording and want to keep it as-is (no converting just keeping it as a MPEG2 file). I have transferred the video file to my MacBook with iTivo (with the decrypt-only setting so that it is kept as-is from the dvr). I then edited out commercials with MPEG Streamclip but otherwise the file is still the same format (no converting, again). When I play the file back with VLC, it looks and sound a-ok. I have burned a copy to a dvd+r dl, once with Toast Titanium and once with the MacBook's own burning abilities. When I play the file back using the blu-ray player, the video breaks up a bit and sound gets a little distorted at those times too -- it appears like a bad video conversion (but which plays fine on the MacBook). I have tried changing settings on the player to playback interlaced (since the original file is 1080i) but it doesn't make a difference.
What I would like to know is if I should consider converting the file to another format that would retain the HD qualities of the original source. what would the source be and can MPEG Streamclip do it?
As a side-note that could be related, when I try to edit a dvr'd file that's in SD, the video doesn't appear (a frame or so intermittently actually) when I try to edit with MPEG Streamclip, just the audio plays. I have the Quicktime MPEG2 plug-in from Apple in order to edit the HD files I've been working with. Any tips on this matter too?
Thanks in advance, and if more info is needed, please ask and I will provide what I can ASAP.
Ben
Still haven't figured this out. Someone elsewhere suggested I try -r instead of +r, but haven't had the chance pick any up yet. Would dig getting more input.
I've now tried different media -- dvd-r instead of +r -- and there is no difference. Help really would be appreciated, please.
Help w/ playback issues on blu-ray player of dvr recording
By bgart13 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2011, 22:02 -
Best Software Player for Blu-Ray Playback
By jet757f in forum Software PlayingReplies: 1Last Post: 5th Aug 2010, 21:58 -
Blu-ray playback issues
By uncleiven in forum Authoring (Blu-ray)Replies: 9Last Post: 23rd Feb 2009, 00:49 -
Blu-ray player with .m2t playback
By michaeltsi in forum DVD & Blu-ray PlayersReplies: 0Last Post: 11th Feb 2009, 16:51 -
Blu-Ray Playback Issues
By ixlspecific2 in forum Software PlayingReplies: 3Last Post: 14th Feb 2008, 16:07
